Connection Drops Regularly - Help Understanding Modem/Router Logs
bonifacefj
I have noticed that my PPPoE connection drops every five minutes  or so.  I've noticed it only between  approximately 1830 every evening and the drop outs seem to stop by 2000 every evening.  This evening, it only happened three times, starting at 1830, other times it drops many more times.  This has been occurring for the last four days, I have not made any significant changes to any related settings or my network for several weeks.
The fact that the issue only occurs at fairly specific times makes me think this is a PlusNet problem rather than a problem on my end.
These are the logs from my DrayTek 2860 Modem Router.  Can anyone help me understand these log entries, I know much more about the internal networking side of things - I'm not completely sure about the WAN side of things.  Immediately after this PPPoE failure, the connection re-establishes and keeps on going just fine.
Time	Message
 2019-11-03 18:41:39	 statistic: Session Usage: 476 (5 min average)
 2019-11-03 18:41:39	 WAN1 PPPoE ==> V:1 T:1 PADI ID:0
 2019-11-03 18:41:39	 WAN1 PPPoE ==> V:1 T:1 PADT ID:2533
 2019-11-03 18:41:34	 [DSL] G.Vectoring Status: OFF
 2019-11-03 18:41:34	 WAN1 PPPoE <== V:1 T:1 PADT ID:2533
 2019-11-03 18:41:34	 WAN1 PPPoE --> send PADT to reset the out-of-order session.
 2019-11-03 18:41:34	 WAN1 PPPoE ==> V:1 T:1 PADT ID:2533
 2019-11-03 18:40:58	 [IPv6] IPv6 WAN1 DOWN!!!
 2019-11-03 18:40:58	  [6in4] Delete WAN IPv6 address: 2001:470:1F1C:37C::2
 2019-11-03 18:40:58	  [IPv6] Clear 6in4 / 6rd tunnel...
 2019-11-03 18:40:58	 WAN 1 is down.
 2019-11-03 18:40:58	 WAN1 PPPoE ==> Protocol:LCP(c021) TermReq Identifier:0x02 ##
 2019-11-03 18:40:30	 WAN1 PPPoE ==> Protocol:LCP(c021) EchoRep Identifier:0x09 Magic Number: 0x0 00 00 ##
 2019-11-03 18:40:30	 WAN1 PPPoE <== Protocol:LCP(c021) EchoReq Identifier:0x09 Magic Number: 0x36d1 8f 37 ##
I don't have any long term logs but I will start saving long tern logs to help track how often it happens.
1 REPLY 1
Fixes: 1,600
Re: Connection Drops Regularly - Help Understanding Modem/Router Logs
Thanks for getting in touch @bonifacefj I'm sorry to see you're experiencing drops in your connection. Line tests aren't showing any issues so it'd be difficult to advise what it may be caused by.
I'd recommend going through some standard troubleshooting steps such as making sure you're using the master socket explained Here, if you've tried a different modem/router and possibly microfilter I'd head on over to http://faults.plus.net to report a fault to us so we can arrange an engineer visit to investigate further.
If you're interested I'm attaching a copy of our test results below:
GEA Test Detail
Circuit ID NA Service ID [Redacted]
Test Outcome Pass
Main Fault Location OK
Sync Status In Sync
Downstream Speed 76.3 Mbps
Upstream Speed 20.0 Mbps
Appointment Required N
Fault Report Advised N
NTE Power Status PowerOn
Voice Line Test Result Pass
Bridge Tap Not Detected
Cross Talk Not Detected
Estimated Line Length In Metres 162.4
Upstream Rate Assessment Very Good
Customer Traffic Level Upstream and Downstream Traffic Detected
Technology VDSL
Current 15Min Bin Retrains 0
Last 15Min Bin Retrains 0
DP Type External
Profile Name 0.128M-80M Downstream, Retransmission Low - 0.128M-20M Upstream, Error Protection Off
Time Stamp 2019-10-22T12:15:00
Parameters MIN MAX AVG
Down Stream Line Rate 79.9 Mbps 79.9 Mbps 79.9 Mbps
Up Stream Line Rate 19.9 Mbps 20.0 Mbps 19.9 Mbps
Up Time 581.0 Sec 900.0 Sec 897.8 Sec
Retrains 0.0 13.0 0.0
Current and Last 15 Minute Bin Performance
Parameters Last Traffic Count(Upto 15 mins) Current Traffic Count(Upto 15 mins)
Start Time Stamp 2019-11-04T11:45:06Z 2019-11-04T12:00:06Z
Ingress Code Violation 0 0
Egress Code Violation 0 0
Errored Seconds 0 0
Severely Errored Seconds 0 0
Unavailable Seconds 0 0
Feel free to let us know how it goes over here.
