Connection Check Please
danludlow
Can you check my connection to see what's what please? TP-Link suggested trying a different modem to see if it improved the disconnect issue, and so i have been running on the Openreach modem for a few days. The connection speed is slower, is my connection using G.INP now? (i don't think my TP-Link modem supports that, my BTO one probably does?).
I'd be very interested to see what's going on if you could post the results please.
Many thanks.
Fixes: 162
Re: Connection Check Please
Here are your connection logs:
Test Outcome Pass
Test Outcome Code GTC_FTTC_SERVICE_0003
Description No problem found, OAM test is not currently supported on this line.
Main Fault Location OK
Sync Status In Sync
Downstream Speed 48.9 Mbps
Upstream Speed 13.6 Mbps
Appointment Required N
Fault Report Advised N
NTE Power Status PowerOn
Voice Line Test Result Pass
Bridge Tap Not Detected
Estimated Line Length In Metres 735.4
Upstream Rate Assessment Very Good
Downstream Rate Assessment Good
Customer Traffic Level Upstream and Downstream Traffic Detected
Profile Name 0.128M-55M Downstream 6dB, Retransmission Low - 0.128M-20M Upstream, Error Protection Off
 Chris Parr
 Plusnet Staff
danludlow
Many Thanks Chris.
