Connection Check Please
FIXED- Subscribe to RSS Feed
- Re: Connection Check Please
13-12-2016 11:55 AM
Can you check my connection to see what's what please? TP-Link suggested trying a different modem to see if it improved the disconnect issue, and so i have been running on the Openreach modem for a few days. The connection speed is slower, is my connection using G.INP now? (i don't think my TP-Link modem supports that, my BTO one probably does?).
I'd be very interested to see what's going on if you could post the results please.
Many thanks.
Fixed! Go to the fix.
13-12-2016 12:47 PM
Here are your connection logs:
Test Outcome | Pass |
Test Outcome Code | GTC_FTTC_SERVICE_0003 |
Description | No problem found, OAM test is not currently supported on this line. |
Main Fault Location | OK |
Sync Status | In Sync |
Downstream Speed | 48.9 Mbps |
Upstream Speed | 13.6 Mbps |
Appointment Required | N |
Fault Report Advised | N |
NTE Power Status | PowerOn |
Voice Line Test Result | Pass |
Bridge Tap | Not Detected |
Repetitive Electrical Impulse Noise | Not Detected |
Estimated Line Length In Metres | 735.4 |
Upstream Rate Assessment | Very Good |
Downstream Rate Assessment | Good |
Interference Pattern | Not Detected |
Service Impact | No Impact Observed |
Home Wiring Problem | Not Detected |
Downstream Policing Discard Rate | 0.0 |
Customer Traffic Level | Upstream and Downstream Traffic Detected |
Profile Name | 0.128M-55M Downstream 6dB, Retransmission Low - 0.128M-20M Upstream, Error Protection Off |
13-12-2016 12:49 PM
Many Thanks Chris.
