Connection Bogging Down
Fixes: 4
Any Chance someone can have a look at my connection please.
2 iperf3 tests below, first test showing the lan card in my laptop not bogging down over my lan to my router, with the second test showing the WAN test bogging down with an iperf3 test from a 10 gigabit server. Also I've popped a screenshot of the Wan side bogging down from TBB below. Changed all cables and ran tests DIRECT with laptop to 2 different modems today with the same results every time.
LAN: laptop card test
 iperf3 -c 192.168.0.254 -R
Connecting to host 192.168.0.254, port 5201
Reverse mode, remote host 192.168.0.254 is sending
[ 4] local 192.168.0.88 port 51264 connected to 192.168.0.254 port 5201
[ ID] Interval Transfer Bandwidth
[ 4] 0.00-1.00 sec 82.5 MBytes 692 Mbits/sec
[ 4] 1.00-2.00 sec 80.7 MBytes 677 Mbits/sec
[ 4] 2.00-3.00 sec 81.8 MBytes 686 Mbits/sec
[ 4] 3.00-4.00 sec 82.4 MBytes 691 Mbits/sec
[ 4] 4.00-5.00 sec 80.9 MBytes 679 Mbits/sec
[ 4] 5.00-6.00 sec 81.9 MBytes 687 Mbits/sec
[ 4] 6.00-7.00 sec 80.3 MBytes 673 Mbits/sec
[ 4] 7.00-8.00 sec 81.6 MBytes 685 Mbits/sec
[ 4] 8.00-9.00 sec 83.2 MBytes 698 Mbits/sec
[ 4] 9.00-10.00 sec 81.5 MBytes 684 Mbits/sec
[ ID] Interval Transfer Bandwidth Retr
[ 4] 0.00-10.00 sec 818 MBytes 686 Mbits/sec 55 sender
[ 4] 0.00-10.00 sec 817 MBytes 685 Mbits/sec receiver
iperf Done.
WAN: modem direct to laptop with above LAN card
/root: iperf3 -c bouygues.testdebit.info -p 5200 -R
Connecting to host bouygues.testdebit.info, port 5200
Reverse mode, remote host bouygues.testdebit.info is sending
[ 4] local xx.xx.xx.xx port 16300 connected to 89.84.127.53 port 5200
[ 4] 0.00-1.00 sec 651 KBytes 5.33 Mbits/sec
[ 4] 1.00-2.00 sec 1.16 MBytes 9.76 Mbits/sec
[ 4] 2.00-3.00 sec 3.78 MBytes 31.7 Mbits/sec
[ 4] 3.00-4.00 sec 3.86 MBytes 32.4 Mbits/sec
[ 4] 4.00-5.00 sec 3.85 MBytes 32.3 Mbits/sec
[ 4] 5.00-6.00 sec 3.86 MBytes 32.4 Mbits/sec
[ 4] 6.00-7.00 sec 3.85 MBytes 32.3 Mbits/sec
[ 4] 7.00-8.00 sec 3.85 MBytes 32.3 Mbits/sec
[ 4] 8.00-9.00 sec 3.85 MBytes 32.3 Mbits/sec
[ 4] 9.00-10.00 sec 3.85 MBytes 32.3 Mbits/sec
[ 4] 0.00-10.00 sec 33.6 MBytes 28.2 Mbits/sec 5 sender
[ 4] 0.00-10.00 sec 32.8 MBytes 27.5 Mbits/sec receiver
iperf Done.
Fixes: 16
Re: Connection Bogging Down
Are you complaining about the 2 to 3 seconds it took for the transfer to reach full speed?
Obviously a LAN connection to your router will have much lower latency than to a server on the Internet, so of course a LAN transfer will speed up quicker.
Have you tested a different computer?
Fixes: 4
Yes I am.
@ejs Does your connection take 2 seconds to get upto full speed on a TBB test ?
I've never had this sort of slowdown on TBB, yes I'll admit some times It's at best inconsistent speed wise, but not slow to respond.
And yes I have also tried several pc's
xdslcmd info --stats
xdslcmd: ADSL driver and PHY status
Status: Showtime
Retrain Reason:	0
Last initialization procedure status:	0
Max:	Upstream rate = 6274 Kbps, Downstream rate = 47412 Kbps
Bearer:	0, Upstream rate = 2000 Kbps, Downstream rate = 40000 Kbps
Bearer:	1, Upstream rate = 0 Kbps, Downstream rate = 0 Kbps
Link Power State:	L0
Mode:			VDSL2 Annex B
VDSL2 Profile:		Profile 17a
TPS-TC:			PTM Mode(0x0)
Trellis:		U:ON /D:ON
Line Status:		No Defect
Training Status:	Showtime
		Down		Up
SNR (dB):	 9.5		 16.6
Attn(dB):	 24.4		 0.0
Pwr(dBm):	 11.2		 0.9
			VDSL2 framing
			Bearer 0
MSGc:		-6		118
B:		138		62
M:		1		1
T:		0		17
R:		8		16
S:		0.1101		0.9907
L:		10684		646
D:		16		1
I:		147		80
N:		147		80
Q:		16		0
V:		12		0
RxQueue:		27		0
TxQueue:		9		0
G.INP Framing:		18		0
G.INP lookback:		9		0
RRC bits:		0		24
			Bearer 1
MSGc:		90		-6
B:		0		0
M:		2		0
T:		2		0
R:		16		0
S:		10.6667		0.0000
L:		24		0
D:		1		0
I:		32		0
N:		32		0
Q:		0		0
V:		0		0
RxQueue:		0		0
TxQueue:		0		0
G.INP Framing:		0		0
G.INP lookback:		0		0
RRC bits:		0		0
			Counters
			Bearer 0
OHF:		0		231280
OHFErr:		0		4
RS:		1355570224		858383
RSCorr:		2722		1352
RSUnCorr:	0		0
			Bearer 1
OHF:		2331455		0
OHFErr:		0		0
RS:		13988358		0
RSCorr:		6		0
RSUnCorr:	0		0
			Retransmit Counters
rtx_tx:		189276		0
rtx_c:		167		0
rtx_uc:		0		0
			G.INP Counters
LEFTRS:		2		0
minEFTR:	40006		0
errFreeBits:	22843814		0
			Bearer 0
HEC:		0		0
OCD:		0		0
LCD:		0		0
Total Cells:	2880623205		0
Data Cells:	137987980		0
Drop Cells:	0
Bit Errors:	0		0
			Bearer 1
HEC:		0		0
OCD:		0		0
LCD:		0		0
Total Cells:	0		0
Data Cells:	0		0
Drop Cells:	0
Bit Errors:	0		0
ES:		0		3
SES:		0		0
UAS:		22		22
AS:		37451
			Bearer 0
INP:		45.00		0.00
INPRein:	0.00		0.00
delay:		0		0
PER:		0.00		16.90
OR:		0.01		58.67
AgR:		40252.99	2059.15
			Bearer 1
INP:		2.50		0.00
INPRein:	2.50		0.00
delay:		0		0
PER:		16.06		0.01
OR:		47.81		0.01
AgR:		47.81	0.01
Bitswap:	21360/21361		2/2
Total time = 10 hours 24 min 33 sec
FEC:		2722		1352
CRC:		0		4
ES:		0		3
SES:		0		0
UAS:		22		22
LOS:		0		0
LOF:		0		0
LOM:		0		0
Latest 15 minutes time = 9 min 33 sec
FEC:		66		0
CRC:		0		0
ES:		0		0
SES:		0		0
UAS:		0		0
LOS:		0		0
LOF:		0		0
LOM:		0		0
Previous 15 minutes time = 15 min 0 sec
FEC:		33		0
CRC:		0		0
ES:		0		0
SES:		0		0
UAS:		0		0
LOS:		0		0
LOF:		0		0
LOM:		0		0
Latest 1 day time = 10 hours 24 min 33 sec
FEC:		2722		1352
CRC:		0		4
ES:		0		3
SES:		0		0
UAS:		22		22
LOS:		0		0
LOF:		0		0
LOM:		0		0
Previous 1 day time = 0 sec
FEC:		0		0
CRC:		0		0
ES:		0		0
SES:		0		0
UAS:		0		0
LOS:		0		0
LOF:		0		0
LOM:		0		0
Since Link time = 10 hours 24 min 9 sec
FEC:		2722		1352
CRC:		0		4
ES:		0		3
SES:		0		0
UAS:		0		0
LOS:		0		0
LOF:		0		0
LOM:		0		0
Fixes: 16
I don't know, don't care, and am not going to measure it, for various reasons including not stopping everyone and everything else using the Internet so I can run tests all evening.
Fixes: 4
This is the second thread you have chimmed in with FUD, please refrain if you have nothing of value to ADD!
adrianscotter
I don't know if this will help or hinder but here are my results in Norwich north.
Sorry, when I looked at the link (removed) it wasn't my results Sad
Nobody argues with you when you're holding a racked Sig Sauer P229 .40
Fixes: 5
@30FTTC06 could be related to the stuff going on on this thread: https://community.plus.net/t5/Fibre-Broadband/Odd-TBB-test/td-p/1393324/jump-to/first-unread-message
What's the MTU set to on your router and the device you're doing the testing on?
Kelly Dorset
Broadband Service Manager
Fixes: 4
@Kelly Yeah I jumped over to that thread to keep it all together.
Thankyou.
Fixes: 4
Just to note 19:59 lost a stream to my laptop from Youtube.
Sooooo.... just turned on my traffic shaper again Sad
