Connecting to home router for "Remote Management"
- Re: Connecting to home router for "Remote Manageme...
21-01-2016 2:32 PM
Morning all, I have a static IP address through Plus Net and have a NetGear R6300v2 router at home. I'd like to be able to access several resources at home, but for now I just need to make a connection to remotely manage the router.
I have enabled "Remote Management", confirmed the port details, allowed access to "Everyone" and checked it is switched on / accessible from my home network. Now when I'm at work I try and connect but continually get "ERR_CONNECTION_TIMED_OUT".
I have then tried traceRT and can see the hostname is correct (so I have the right IP address) but the last hop is within the plus net server farm
link-a-central10.pcl-ag07.plus.net [212.159.2.18 5]
(occasionally it stops at "xe0-0-7-pr2.lon.router.colt.net [212.74.72.117]" before I get a timeout)
The view of plusnet is traceRT and other ping responses are disabled within their network, meaning I have no method of troubleshooting or isolating where the problem is.
Any ideas?
Any ideas?
Message 1 of 6
(1,831 Views)
5 REPLIES 5
Re: Connecting to home router for "Remote Management"
21-01-2016 3:31 PM
Are you going in on port 8080?
Try http://'your ip or hostname':8080
Message 2 of 6
(1,492 Views)
21-01-2016 3:53 PM
That's pretty much what I'm doing, and have tried port 8443 as suggested elsewhere.
Also tried DNS refreshes and a host of other things, hence the traceRT to see where the issue is
Message 3 of 6
(1,492 Views)
21-01-2016 3:54 PM
Message 4 of 6
(1,492 Views)
21-01-2016 4:03 PM
I just looked at the manual for your router and although the text states the default port is 8080, the image actually shows port 8443 as the previous poster stated.
Whichever port is used, it will show it in that menu on your router, so what port does that say?
Message 5 of 6
(1,492 Views)
21-01-2016 5:01 PM
and make sure your PlusNet Firewall is not set to High https://portal.plus.net/my.html?action=firewall you'll need to login to the member centre . If you have to change it then you will need to disconnect/reconnect the ppp session for it to take effect
Message 6 of 6
(1,492 Views)
