Connecting billion router to open reach modem
- Re: Connecting billion router to open reach modem
07-09-2015 9:02 PM
TIA
Trevor
Ps. After 8 hours problem has cleared by itself but it would still be good to know how to use the billion router. I'll post screenshots of errors I was getting to see if anyone else experienced similar probs
Bizzare connection to sky router earlier today
07-09-2015 9:08 PM
Anybody else experienced a similar problem?
Trevor
07-09-2015 9:25 PM
Re: Bizzare connection to sky router earlier today
07-09-2015 9:30 PM
07-09-2015 11:48 PM
Regarding the issue you had getting a Sky router login, I'd diagnose that as you are using powerline adapters to extend your network and you've left them on there default security settings? If I'm right, so has one of your neighbours! Read up on how to change their authentication settings with a password of your choosing.
08-09-2015 11:57 AM
08-09-2015 12:10 PM
08-09-2015 12:36 PM
08-09-2015 1:53 PM
Quote from: georgelnx And now your neighbour is too, and using the same settings as yourself. I would change the settings on yours to avoid this clash.
But ip address of routers different ?
Back using original seetings and touch wood all OK. Nothing changed on my network?
And why didn't plusnet suggest this instead of sending out new router (still to arrive?)
Trevor
08-09-2015 2:04 PM
Just changed to solwise plugs couple weeks ago big speed improvements. Sky issue only happened Monday
Trevor
11-09-2015 12:30 PM
11-09-2015 12:49 PM
