Connecting BT SmartHub A router to PlusNet
janduggy
Plusnet router is poor and have been assured can use my BT SmartHub A router.  However really struggling to set this up - Can anyone help please?
3 REPLIES 3
Fixes: 418
Re: Connecting BT SmartHub A router to PlusNet
@janduggy  Welcome to the forum.
See here for Smarthub setting up instructions. https://community.plus.net/t5/My-Router/Using-the-BT-Smarthub-6-on-a-Plusnet-Account/m-p/1587673#M85...
Take particular note of when to plug in the DSL lead. Let us know if you have problems.
janduggy
Plugged in DSL lead (have open reach box so haven't needed a filter)... but just can't connect through the BT advanced settings...
LifeonMars
Seasoned Pro
Fixes: 12
Take a look at my post 41 here
https://community.plus.net/t5/ADSL-Broadband/BT-Home-Hub-6-Smart-Hub-on-PlusNet/m-p/1415464#M312705
Do not plug in the DSL line until you have altered your passwords etc and are ready to connect.
Do not use any odd characters for your password either the BT Router will not accept !@£$%^&*()_ . etc
If you have a brand new BT Smart hub then a reset should not be necessary.
