Connected but no Internet
FIXEDTopic Options
- Re: Connected but no Internet
04-03-2021 10:25 PM
Tonight my Internet went off without any explanation. It says that it's connected but no Internet. I've tried resting the router but to no avail. Also been into the router settings to make sure they are okay and it's just that connection to the Internet that I can't get back on. I can't find any obvious outages reported and I'm a bit stuck. Not much use with customer services being closed at 8pm either.
Fixed! Go to the fix.
Message 1 of 2
(1,041 Views)
1 REPLY 1
04-03-2021 10:38 PM
All sorted now typical after posting for help.
Message 2 of 2
(1,030 Views)
