Confirming an upgrade order is in the works...?
- Confirming an upgrade order is in the works...?
18-12-2014 9:10 PM
We placed a product change request via the member portal on 14/12/14 for a FTTC upgrade - but just wondering if / how I can find some sort of confirmation that it's lined up to happen?
Was expecting to see a ticket appear in our account with details or something similar, but other than one email confirming an engineer appt request for 22/12, I've not had anything else.
Anyone have any ideas? Is this normal... ? Do we just wait for the 22nd and see if an engineer turns up?
Message 1 of 3
(560 Views)
2 REPLIES 2
Re: Confirming an upgrade order is in the works...?
19-12-2014 9:55 AM
Hi there.
I can confirm that the order is on our suppliers systems and the engineer is due to visit on the 22nd.
From what I can see you haven't taken a router from ourselves so I'm assuming you'll be using your own?
If you have any further issues please let us know.
Message 2 of 3
(328 Views)
19-12-2014 11:49 AM
Hi Matthew, that's great - thanks for confirming.
Fingers crossed the engineer turns up.
We have a BT Home Hub 5 which I'm planning to use for the connection along with a backup plan in the form of another router to connect to the Openreach modem.
Message 3 of 3
(328 Views)
