Config for Ubiquiti ER-X EdgeRouter X on Plusnet FTTC
- Re: Config for Ubiquiti ER-X EdgeRouter X on Plusn...
13-02-2016 8:46 AM
Configuring the ER-X took some research. Many thanks to those who have posted their experiences. Here is my config.boot, edited to remove names and passwords. It enables the inbuilt 4-port switch, opens a port for forwarding, has some static routes and provides local DNS with some static local hosts. It also enable 24V POE for the UAP-AC-LR on eth4. I had problems with downloading some web sites until I added the modify rule in the firewall (to keep all packets within the 1492 MTU).
Hope this helps!
firewall {
all-ping enable
broadcast-ping disable
ipv6-receive-redirects disable
ipv6-src-route disable
ip-src-route disable
log-martians enable
modify pppoe-out {
rule 1 {
action modify
modify {
tcp-mss 1452
protocol tcp
tcp {
flags SYN
name WAN_IN {
default-action drop
description "WAN to internal"
rule 10 {
action accept
description "Allow established/related"
state {
established enable
related enable
rule 20 {
action drop
description "Drop invalid state"
state {
invalid enable
name WAN_LOCAL {
default-action drop
description "WAN to router"
rule 10 {
action accept
state {
established enable
related enable
rule 20 {
action drop
state {
invalid enable
send-redirects enable
source-validation disable
syn-cookies enable
interfaces {
ethernet eth0 {
address dhcp
description Internet
duplex auto
pppoe 0 {
default-route auto
firewall {
in {
name WAN_IN
local {
name WAN_LOCAL
out {
modify pppoe-out
mtu 1492
name-server none
password yourplusnetpassword
user-id yourusername@plusdsl.net
speed auto
ethernet eth1 {
description Local
duplex auto
speed auto
ethernet eth2 {
description Local
duplex auto
speed auto
ethernet eth3 {
description Local
duplex auto
speed auto
ethernet eth4 {
description Local
duplex auto
poe {
output pthru
speed auto
loopback lo {
switch switch0 {
address 192.168.77.1/24
description Local
mtu 1500
switch-port {
interface eth1
interface eth2
interface eth3
interface eth4
port-forward {
auto-firewall enable
hairpin-nat enable
lan-interface switch0
rule 1 {
description vpn
forward-to {
address 192.168.77.77
port 1194
original-port 1194
protocol udp
wan-interface pppoe0
protocols {
static {
route 10.8.0.0/24 {
next-hop 192.168.77.77 {
route 192.168.80.0/24 {
service {
dhcp-server {
disabled false
hostfile-update disable
shared-network-name my_dhcp {
authoritative disable
subnet 192.168.77.0/24 {
default-router 192.168.77.1
dns-server 192.168.77.1
lease 86400
start 192.168.77.100 {
stop 192.168.77.243
dns {
forwarding {
cache-size 150
listen-on switch0
name-server 8.8.8.8
name-server 8.8.4.4
gui {
https-port 443
nat {
rule 5010 {
log disable
outbound-interface pppoe0
protocol all
type masquerade
ssh {
port 22
protocol-version v2
system {
host-name ubnt
login {
user yourusername {
authentication {
encrypted-password longstringofrandomhex
plaintext-password ""
level admin
ntp {
server 0.ubnt.pool.ntp.org {
server 1.ubnt.pool.ntp.org {
server 2.ubnt.pool.ntp.org {
server 3.ubnt.pool.ntp.org {
static-host-mapping {
host-name name1 {
inet 192.168.77.77
host-name name2 {
inet 192.168.80.93
host-name name3 {
inet 192.168.77.12
syslog {
global {
facility all {
level notice
facility protocols {
level debug
time-zone UTC
Re: Config for Ubiquiti ER-X EdgeRouter X on Plusnet FTTC
21-05-2016 9:11 AM
I've tried setting this up a couple of times and have had no joy - did it take a while to sync or anything like that? I'm logging a successful connection but it gives me a 172.0.0.0 address instead of my static IP and I can't connect to anything.
21-05-2016 12:01 PM
The most common reason for an address in the private range of 172.16.0.0 - 172.31.255.255 is that there is an error in the username or password fields used to create the PPPoE link, so the connection works but you cannot be logged in by the Radius servers.
The username is in the format username@plusdsl.net and the password is the one used to log into the Plusnet members centre.
22-05-2016 9:34 AM
Ah yes, that's part of the problem. I'll give it another try.
23-05-2016 2:19 PM
Got it working now. The password was the first issue. I got that right and the connection came up.
However, I think I've come across something which may trip up other people so I'll add it as a note.
I intend to use the router with another connection in a load balancing config, which had been set up previously, so I left eth0 unconnected for the second connection and reset the router. I brought up the pppoe connection on eth1 and configured a switch for my home network but couldn't get a connection between the switch and the Internet. Now, I can hear several people jumping up and down with their hands up... That doesn't work if you don't have load balancing configured. You have to use eth0 as the connection. Connect the modem to eth0 and then connectivity comes up once the pppoe connection has sorted itself out.
25-05-2016 8:42 AM - edited 25-05-2016 8:45 AM
Just to add something else - I found that I had problems with a few sites as andy753 mentioned - generally CDN type services either not responding at all or not delivering static files. Enabling TCP MSS clamping using the Feature Wizard in the Wizards tab fixed this.
29-12-2016 3:47 PM - edited 29-12-2016 3:52 PM
I just got mine up and running and saw this post. I had the same problem, some sites where not loading or connections where very slow to load. TCP MSS clamping helped me to start with, but I found a different solution that might help some users.
This will only work if your modem supports jumbo frames (mtu 1500>). I have a Draytek Vigor 130 and it work very well.
Set your MTU for the connection to your modem to 1508, once you save this it will allow you to increase the MTU for your PPPoE connection to 1500.
Now you don't need MSS Clamping and it might help if you enable the OFFLOAD function for 'forwarding' and 'pppoe' to speedup your edge router (if your model supports this).
interfaces { ethernet eth0 { address 10.0.1.1/24 description "Local Network 1" duplex auto speed auto } ethernet eth1 { address 192.168.2.10/24 description "Internet (PPPoE)" duplex auto mtu 1508 pppoe 0 { default-route auto firewall { in { name WAN_IN } local { name WAN_LOCAL } } mtu 1500 name-server auto password ******** user-id *******@plusdsl.net } speed auto } ethernet eth2 { address 10.0.2.1/24 description "Local Network 2" duplex auto speed auto }
You can check if it works on http://www.letmecheck.it/mtu-test.php
The maximum MTU size for ***.***.***.*** is: 1500
I gained a good 5Mb/s increase with this configuration over the standard Plusnet router thingy .
16-12-2017 11:18 AM
Given this is the top Google result for using Plusnet with an Edgerouter, I would like to add that a better option for doing the MSS clamping if configuring it via the command line is to do
set firewall options mss-clamp interface-type pppoe set firewall options mss-clamp mss 1452
Compared to using the modify firewall rule in the original post this has the advantage of not disabling the hardware acceleration for NAT, which will give a performance boost. Probably similar to that you can gain by setting the MTU to 1508 if you have a Draytek 130 modem instead of one of the Openreach provided ones.
