Coming back
OskarPapa
Fixes: 65
Re: Coming back
Hi @npr, thanks for updating us all.
Please let us all know how you get on with the new cab, I for one am keen to see how it performs over time.
npr
Fixes: 9
Re: Coming back
Update:
G.INP has been activated on the downstream giving the following changes:
Downstream sync increase from 23312 Kbps to 26490 Kbps.
Upstream sync decreased from 1936 Kbps to 1809 Kbps.
Minimum latency has also dropped from 20ms to 12ms.
iangilf
Re: Coming back
hence why all cabs should of been huawei cabinets instead of eci cabs
nice 1 i bet your more happier now ? also what are your attenuation stats ?
npr
Fixes: 9
Re: Coming back
@iangilf
Is this what you want to see?
Stats from Huawie cabinet 20/4/19
xdslctl info --stats xdslctl: ADSL driver and PHY status Status: Showtime Last Retrain Reason: 0 Last initialization procedure status: 0 Max: Upstream rate = 1869 Kbps, Downstream rate = 26742 Kbps Bearer: 0, Upstream rate = 1869 Kbps, Downstream rate = 26727 Kbps Bearer: 1, Upstream rate = 0 Kbps, Downstream rate = 0 Kbps Link Power State: L0 Mode: VDSL2 Annex B VDSL2 Profile: Profile 17a TPS-TC: PTM Mode(0x0) Trellis: U:ON /D:ON Line Status: No Defect Training Status: Showtime Down Up SNR (dB): 6.4 6.2 Attn(dB): 28.2 0.0 Pwr(dBm): 12.3 6.1 VDSL2 framing Bearer 0 MSGc: -6 26 B: 243 47 M: 1 1 T: 0 63 R: 10 0 S: 0.0000 0.8101 L: 6990 474 D: 8 1 I: 254 48 N: 254 48 Q: 8 0 V: 0 0 RxQueue: 20 0 TxQueue: 10 0 G.INP Framing: 18 0 G.INP lookback: 10 0 RRC bits: 0 24 Bearer 1 MSGc: 90 -6 B: 0 0 M: 2 0 T: 2 0 R: 16 0 S: 10.6667 0.0000 L: 24 0 D: 1 0 I: 32 0 N: 32 0 Q: 0 0 V: 0 0 RxQueue: 0 0 TxQueue: 0 0 G.INP Framing: 0 0 G.INP lookback: 0 0 RRC bits: 0 0 Counters Bearer 0 OHF: 0 1077066 OHFErr: 0 0 RS: 188283472 3414842 RSCorr: 10868 0 RSUnCorr: 0 0 Bearer 1 OHF: 855284 0 OHFErr: 0 0 RS: 5131331 0 RSCorr: 16 0 RSUnCorr: 0 0 Retransmit Counters rtx_tx: 5193 0 rtx_c: 407 0 rtx_uc: 0 0 G.INP Counters LEFTRS: 10 0 minEFTR: 26720 0 errFreeBits: 5591345 0 Bearer 0 HEC: 0 0 OCD: 0 0 LCD: 0 0 Total Cells: 706102047 0 Data Cells: 35011236 0 Drop Cells: 0 Bit Errors: 0 0 Bearer 1 HEC: 0 0 OCD: 0 0 LCD: 0 0 Total Cells: 0 0 Data Cells: 0 0 Drop Cells: 0 Bit Errors: 0 0 ES: 0 0 SES: 0 0 UAS: 26 26 AS: 13743 Bearer 0 INP: 44.00 0.00 INPRein: 0.00 0.00 delay: 0 0 PER: 0.00 12.80 OR: 0.01 19.98 AgR: 26754.70 1888.62 Bearer 1 INP: 2.50 0.00 INPRein: 2.50 0.00 delay: 0 0 PER: 16.06 0.01 OR: 47.81 0.01 AgR: 47.81 0.01 Bitswap: 363/363 1/1 Total time = 3 hours 49 min 29 sec FEC: 10868 0 CRC: 0 0 ES: 0 0 SES: 0 0 UAS: 26 26 LOS: 0 0 LOF: 0 0 LOM: 0 0 Latest 15 minutes time = 4 min 29 sec FEC: 64 0 CRC: 0 0 ES: 0 0 SES: 0 0 UAS: 0 0 LOS: 0 0 LOF: 0 0 LOM: 0 0 Previous 15 minutes time = 15 min 0 sec FEC: 118 0 CRC: 0 0 ES: 0 0 SES: 0 0 UAS: 0 0 LOS: 0 0 LOF: 0 0 LOM: 0 0 Latest 1 day time = 3 hours 49 min 29 sec FEC: 10868 0 CRC: 0 0 ES: 0 0 SES: 0 0 UAS: 26 26 LOS: 0 0 LOF: 0 0 LOM: 0 0 Previous 1 day time = 0 sec FEC: 0 0 CRC: 0 0 ES: 0 0 SES: 0 0 UAS: 0 0 LOS: 0 0 LOF: 0 0 LOM: 0 0 Since Link time = 3 hours 49 min 1 sec FEC: 10868 0 CRC: 0 0 ES: 0 0 SES: 0 0 UAS: 0 0 LOS: 0 0 LOF: 0 0 LOM: 0 0 NTR: mipsCntAtNtr=0 ncoCntAtNtr=0 ~ #
npr
Fixes: 9
Re: Coming back
@OskarPapa
The connection has now had it's 10 days settling in period so the following result should be the norm for my line on the new Huawei cabinet.
First a reminder of the stats From the old ECI cabinet:
Stats recorded 28 Apr 2018 23:47:48
DSLAM/MSAN type:            IFTN:0xd086 / v0xd086
Modem/router firmware:      AnnexA version - A2pv6F039v.d26a
DSL mode:                   VDSL2 Profile 17a
Status:                     Showtime
Uptime:                     2 days 2 hours 57 min 15 sec
Resyncs:                    1 (since 26 Apr 2018 20:17:44)
                Downstream    Upstream
Line attenuation (dB):      30.4        0.0
Signal attenuation (dB):    Not available on VDSL2
Connection speed (kbps):    22199        598
SNR margin (dB):            6.6        6.4
Power (dBm):                12.0        4.3
Interleave depth:           389        1
INP:                        3.00        0
G.INP:                      Not enabled        Not enabled
Vectoring status:           5 (VECT_UNCONFIGURED)
RSCorr/RS (%):              0.3025        0.0013
RSUnCorr/RS (%):            0.0041        0.0000
ES/hour:                    2.15        0
Speed tests: in the order of 20Mbps down 0.5Mbps up
IP profile: not known
Minimum latency: around 20ms
Stats from the new Huawei cabinet:
Stats recorded 28 Apr 2019 18:07:52
DSLAM type / SW version:    BDCM:0xa48c (164.140) / v0xa48c
Status:                     Showtime
Uptime:                      1 hour 41 min 7 sec
Resyncs:                    5 (since 24 Apr 2019 17:17:45)
                Downstream    Upstream
Line attenuation (dB):      28.1        0.0
Signal attenuation (dB):    Not monitored
Connection speed (kbps):    31018        1853
SNR margin (dB):            3.4        6.2
Power (dBm):                12.4        6.0
Interleave depth:           4        1
INP:                        49.00        0
G.INP:                      Enabled        Not enabled
RSCorr/RS (%):              0.0516        0.0000
RSUnCorr/RS (%):            0.0000        0.0000
ES/hour:                    0        0.06
Speed tests: in the order of 26Mbps down (1.3x increase), 1.7Mbps up (3.4x increase)
IP profile: 27Mbps down
Minimum latency: around 12ms
MatthewWheeler
Fixes: 479
Re: Coming back
Glad to hear you've seen an improvement.
Let us know if you have any further issues.
 Matthew Wheeler
