Cisco ROuter configuration for Plusnet Fibre Broadband
- Cisco ROuter configuration for Plusnet Fibre Broad...
12-12-2015 1:51 PM
Hi guys,
Im trying to configure my cisco router 2610XM with my fibre line. Just to explain the physical configuration the plusnet modem is connected to my cisco router through Fa0/0, I have a hwic slot but nothing is connected through this, My pc is then directly connected to the router or a switch. The issue i'm having is that thought the router has picked up an IP, you can ping websites from the router itself, which to me says there is connectivity there. However I am still not able to access the internet with my directly connected PC.
Please have a look at the conflict below and advise where i may be going wrong.
Building configuration...
Current configuration : 2538 bytes
version 12.4
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname Test
boot-start-marker
boot-end-marker
enable secret 5 $1$85TC$Evl8//7gtUbeV5.5bDy3H0
no aaa new-model
no network-clock-participate slot 1
no network-clock-participate wic 0
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.1.1 192.168.1.50
ip dhcp excluded-address 192.168.1.250 192.168.1.255
ip dhcp pool LAN
import all
network 192.168.1.0 255.255.255.0
dns-server 212.159.13.49 212.159.13.50
default-router 192.168.1.254
ip name-server 212.159.13.49
ip name-server 212.159.13.50
multilink bundle-name authenticated
archive
log config
hidekeys
interface FastEthernet0/0
description DSL INTERFACE
bandwidth 10000000
no ip address
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 1
interface Serial0/0
no ip address
shutdown
no fair-queue
interface ATM0/1
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
no ip mroute-cache
atm vc-per-vp 128
no atm ilmi-keepalive
dsl operating-mode auto
hold-queue 224 in
pvc 0/38
oam-pvc 0
encapsulation aal5mux ppp dialer
dialer pool-member 1
interface FastEthernet0/1
bandwidth 10000000
ip address 192.168.1.254 255.255.255.0
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
interface Dialer1
bandwidth 10000000
ip address negotiated
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1492
ip nat outside
encapsulation ppp
ip route-cache flow
dialer pool 1
ppp authentication chap callin
ppp chap hostname xxxx@plusdsl.net
ppp chap password 7
ppp ipcp dns request
ppp ipcp wins request
hold-queue 224 in
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer1
ip http server
no ip http secure-server
ip nat inside source list INSIDE_NAT-ADDRESSES interface Dialer1 overload
ip access-list standard INSIDE_NAT_ADDRESSES
permit 192.168.1.0 0.0.0.255
permit 192.168.2.0 0.0.0.255
control-plane
dial-peer cor custom
line con 0
exec-timeout 0 0
password 7
logging synchronous
login
line aux 0
line vty 0 4
exec-timeout 0 0
password 7
login
transport input telnet
end
Interface IP-Address OK? Method Status Protocol
FastEthernet0/0 unassigned YES NVRAM up up
Serial0/0 unassigned YES NVRAM administratively down down
ATM0/1 unassigned YES NVRAM down down
FastEthernet0/1 192.168.1.254 YES NVRAM up up
NVI0 unassigned YES unset administratively down down
Virtual-Access1 unassigned YES unset up up
Virtual-Access2 unassigned YES unset up up
Virtual-Access3 unassigned YES unset up up
Dialer1 105.xx.xx.xx YES IPCP up up
Show ip route
195.166.128.0/32 is subnetted, 1 subnets
C 195.166.128.228 is directly connected, Dialer1
C 192.168.1.0/24 is directly connected, FastEthernet0/1
105.xxx.xx.0/32 is subnetted, 1 subnets
C 105.xxx.xx.xx is directly connected, Dialer1
S* 0.0.0.0/0 is directly connected, Dialer1
Note i obviouslt havent used my real public ip addressn (hopefully )
version 12.4
hostname Test
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
ip dhcp pool LAN
import all
archive
log config
hidekeys
bandwidth 10000000
no ip address
duplex auto
speed auto
interface Serial0/0
no ip address
shutdown
no fair-queue
interface ATM0/1
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
no ip mroute-cache
atm vc-per-vp 128
hold-queue 224 in
pvc 0/38
oam-pvc 0
bandwidth 10000000
ip nat inside
duplex auto
speed auto
interface Dialer1
bandwidth 10000000
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1492
ip nat outside
encapsulation ppp
ip route-cache flow
dialer pool 1
ppp chap password 7
hold-queue 224 in
ip http server
control-plane
line con 0
exec-timeout 0 0
password 7
logging synchronous
login
line aux 0
line vty 0 4
exec-timeout 0 0
password 7
login
end
Show ip route
Message 1 of 4
(1,698 Views)
3 REPLIES 3
Re: Cisco ROuter configuration for Plusnet Fibre Broadband
12-12-2015 3:14 PM
Message 2 of 4
(1,334 Views)
05-01-2018 10:04 AM
Message 3 of 4
(1,117 Views)
05-01-2018 11:39 AM
I don't think you'll get a reply from @whoopty as this thread is over 2 years old and he hasn't been seen in the forums since April 2016.
