Cisco AnyConnect stopped working
- Cisco AnyConnect stopped working
19-08-2019 2:45 PM
Recently i've stopped being able to conenct to my work VPN through Cisco Anyconnect.
It was working fine before hand and then one afternoon (possibly 26th July), it disconnected and I haven't been able to connect since. I've connected via Cellular, guest wifi and all sorts without issue.
It just seems to spin away trying to connect, without connecting.
Is there anything i can check? Nothing had been changed on the Router / PC prior to this happening.
Any suggestions appreciated.
Cheers
Stu
Re: Cisco AnyConnect stopped working
30-08-2019 7:58 AM
Nothing on this? I've enabled Port Clamping and disabled the firewall and had neither work. Nor does it work connected by ethernet
I've only recently signed back up for 18 months. Where do i stand if i want to terminate that due to my connection not working as it did previously?
Cheers
Stu
03-09-2019 8:34 AM
Hi @stu1892 Thanks for your post and I'm sorry for the delayed response publicly. It looks like my colleague Matt got this sorted for you Friday afternoon. If you need any further help, please do feel free to let us know.
