Chromecast and hub one
- Re: Chromecast and hub one
18-01-2016 11:57 AM
Unable to setup my Chromecast (version 1) with my Hub One router. Worked fine with previous BB suppler. Chromecast help suggests AP isolation with dual band routers may be the cause but I can't find a setting on the router.
Has any one got this working?
Thanks Kieran
Thanks Kieran
Message 1 of 9
(2,456 Views)
8 REPLIES 8
18-01-2016 12:09 PM
you need to change the ssid of the 5ghz.
you can find it in advance settings > wireless > 5ghz wireless
18-01-2016 12:13 PM
Thanks, can you clarify as to what I change the SSID to?
Message 3 of 9
(2,064 Views)
18-01-2016 12:14 PM
anything you want really - i just stuck a 5 on the end of mine.
18-01-2016 12:20 PM
Router won't allow SSID change on 5GHz only on 2.4 unless I disable Sync with 2.4 GHz.
Message 5 of 9
(2,064 Views)
18-01-2016 12:23 PM
I set up the wifi on mine allowing same settings on both.
I then unticked the 'sync' box and added a '5' to the end of the 5GHz.
18-01-2016 12:25 PM
Did you then leave it unticked?
Message 7 of 9
(2,064 Views)
18-01-2016 6:05 PM
Yes.
19-01-2016 2:21 PM
No luck with the desktop, I got it going using my tablet!
Thanks for the help.
Kieran
Kieran
Message 9 of 9
(2,064 Views)
