Checking my fibre speed
Baybeebug
Can someone at plusnet please check what speed I'm supposed to be on for my fibre broadband please as the website is saying 36mb average, but I'm getting no where near that and haven't since I changed over to fibre. Thank you
Seasoned Champion
Fixes: 41
Re: Checking my fibre speed
Do you mean that Plusnet have guaranteed 38Mbps or that you are on the up to 38Mbps aervice. Put your phone number in here to see what your line is capable of   https://www.dslchecker.bt.com/
What speed are you getting with a wired Ethernet cable between your router and computer and your router plugged into your BT master socket via a filter?
Fixes: 181
Sorry to hear you're having issues with your speeds.
You're definitely on a fibre service as shown from the test of your line below.
Test Outcome Pass
Main Fault Location OK
Sync Status In Sync
Downstream Speed 11.4 Mbps
Upstream Speed 0.6 Mbps
Appointment Required N
Fault Report Advised N
NTE Power Status PowerOn
Voice Line Test Result Pass
Bridge Tap Not Detected
Estimated Line Length In Metres 1738.3
Upstream Rate Assessment Very Good
Downstream Rate Assessment Reasonable
Interference Pattern Regular Interference Observed Daily
Interference Duration Longest Occurrence From 00:45 to 04:15
Interference Location Customer Premise
Interference Observed In Days 14
Customer Traffic Level Upstream and Downstream Traffic Detected
Technology VDSL
Profile Name 0.128M-11.4M Downstream, Interleaving Low - 0.128M-10M Upstream, Error Protection Off
Time Stamp 2018-05-17T11:45:00
Parameters MIN MAX AVG
Down Stream Line Rate 11.3 Mbps 11.3 Mbps 11.3 Mbps
Up Stream Line Rate 0.6 Mbps 0.6 Mbps 0.6 Mbps
Up Time 886.0 Sec 900.0 Sec 899.9 Sec
Retrains 0.0 0.0 0.0
Current and Last 15 Minute Bin Performance
Parameters Last Traffic Count(Upto 15 mins) Current Traffic Count(Upto 15 mins)
Start Time Stamp 2018-05-30T11:18:55.253+01:00 2018-05-30T11:33:55.253+01:00
Ingress Code Violation 0 0
Egress Code Violation 0 0
Errored Seconds 0 0
Severely Errored Seconds 0 0
Unavailable Seconds 0 0
From what I can see when you signed up we gave you between 9 and 15mbps as your estimated speed.
Unfortunately as you are within this range there isn't anything we can do to progress this further.
 Matthew Wheeler
