Check on data consumption?
- Check on data consumption?
27-10-2019 11:39 AM
I usually have my radio on in the background at night as it helps me sleep. Until the last few days I only listened to broadcast on-air radio but have just discovered the Tune-In internet service which provides a better range. Since I am now consuming 8 extra hours a day of data, and have also added a couple of Nest cameras, I am concerned I could be using unreasonable amounts of data. Where can I keep an eye on this to ensure I keep within reasonable limits?
Re: Check on data consumption?
27-10-2019 1:18 PM
Assuming your on an unlimited plan, you have nothing to worry about, you can you as much data as you want 😀
27-10-2019 3:22 PM
Well I don't like the thought that I might impact on other people's service, so I'd really like to have some kind of meter to show how it's going and compare to average expected levels etc. Isn't there one?
27-10-2019 3:48 PM
@IngeJones If it were metered you would see that the load on the network is miniscule.
27-10-2019 4:07 PM - edited 27-10-2019 4:08 PM
Do you have a Hub One? That will tell you on the Helpddesk how much data has gone up and down the line, since the last Hub restart.
27-10-2019 4:35 PM
@IngeJones wrote:
Well I don't like the thought that I might impact on other people's service...
Very commendable, but I really wouldn't be concerned.
The net's infrastructure has grown over the years to accommodate millions of users downloading and streaming from multiple platforms - mainly video. Radio streaming is a miniscule part of it.
Zen FTTC 40/10 + Digital Voice FRITZ!Box 7530
BT technician (Retired)
27-10-2019 5:19 PM
Internet radio on 24/7 will use between 2 and 4GB per month. This is peanuts compared with steaming video. I consider myself to be a lightweight streamer but use between 40 and 60 GB per month.
27-10-2019 6:05 PM
Plusnet used to provide a monitoring feature, but it has recently been removed. If they aren't worried about a unlimited connection using too much data, neither should you.
27-10-2019 9:34 PM - edited 27-10-2019 9:35 PM
Ok thanks everyone, I shall relax and enjoy.
