Channel4
- Channel4
Channel4
29-03-2016 10:22 AM
tried a Tracert to Chan 4 and got this ?
Re: Channel4
29-03-2016 10:42 AM
3 tests all same ?
Re: Channel4
29-03-2016 10:52 AM
Re: Channel4
29-03-2016 11:23 AM
Re: Channel4
29-03-2016 11:24 AM
Tracing route to channel4.com [83.98.28.10]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms home.gateway.home.gateway [192.168.1.254]
2 12 ms 11 ms 13 ms lo0.10.Central10.ptn-bng02.plus.net [195.166.130.190]
3 12 ms 12 ms 12 ms irb.10.PTW-CR01.plus.net [84.93.249.1]
4 12 ms 12 ms 12 ms 195.99.126.138
5 14 ms 13 ms 13 ms core3-te0-0-0-15.faraday.ukcore.bt.net [213.121.193.164]
6 12 ms 12 ms 13 ms peer2-et-10-3-0.faraday.ukcore.bt.net [62.6.201.199]
7 13 ms 13 ms 13 ms 213.137.183.102
8 15 ms 13 ms 14 ms 82.112.115.185
9 14 ms 14 ms 14 ms ae-13.r02.londen03.uk.bb.gin.ntt.net [129.250.2.118]
10 14 ms 15 ms 14 ms ae-1.r00.londen10.uk.bb.gin.ntt.net [129.250.3.31]
11 13 ms 20 ms 13 ms 82.112.101.98
12 * * * Request timed out.
13 * *
Re: Channel4
29-03-2016 11:27 AM
Re: Channel4
29-03-2016 12:58 PM
mine says 205.core.plus.net ?
thought the second hop was the gateway ?
Re: Channel4
29-03-2016 1:02 PM
Re: Channel4
29-03-2016 1:29 PM
Quote from: rongtw thought the second hop was the gateway ?
New Network by the looks, mine times out after the *.98 IP also.
If you Like it, give it a
Re: Channel4
29-03-2016 2:16 PM
just checked gateway checker it says , You are currently connected to gateway pcl-ag02.
Re: Channel4
29-03-2016 5:08 PM
Re: Channel4
29-03-2016 5:09 PM
