Change reverse DNS entry from username to an IP or anonymous name
richardmk
Hi
Does anyone know how I get my reverse DNS lookup changed from <myname>.plus.com to something without my name in it.
Richard
Fixes: 162
Re: Change reverse DNS entry from username to an IP or anonymous name
I can sort that for you, would you just like it changing to IP.plus.com ?
 Chris Parr
 Plusnet Staff
sirhc
Yes, I have had this done and you just need to raise a ticket and they'll do it for you. Can either be custom rdns (if you have a domain) or they can set it up a generic (yourip).plus.com
Edit; just seen the reply from Chris so if you get him to do it that might be the quickest way.
Fixes: 62
CrystalJayme
@Chris could you also change mine please to IP.com thank you
Update: Amended to .com
Fixes: 162
It would be IP.plus.com, is that ok?
 Chris Parr
 Plusnet Staff
CrystalJayme
@Chris - Yep that's fine thank you will I need to restart my router and will my gateway change?
Fixes: 162
Nope, you won't need to do anything. It takes around 24 hours to update but I've just put that through now.
 Chris Parr
 Plusnet Staff
CrystalJayme
@Chris - Thank you I'm very grateful  Kiss
