Change reverse DNS entry from username to an IP or anonymous name
- Re: Change reverse DNS entry from username to an I...
19-10-2015 5:00 PM
Hi
Does anyone know how I get my reverse DNS lookup changed from <myname>.plus.com to something without my name in it.
Richard
Richard
Message 1 of 9
(2,266 Views)
8 REPLIES 8
Re: Change reverse DNS entry from username to an IP or anonymous name
19-10-2015 5:03 PM
I can sort that for you, would you just like it changing to IP.plus.com ?
Message 2 of 9
(1,880 Views)
19-10-2015 5:04 PM
Yes, I have had this done and you just need to raise a ticket and they'll do it for you. Can either be custom rdns (if you have a domain) or they can set it up a generic (yourip).plus.com
Edit; just seen the reply from Chris so if you get him to do it that might be the quickest way.
Message 3 of 9
(1,880 Views)
19-10-2015 5:07 PM
Message 4 of 9
(1,880 Views)
21-10-2015 9:42 AM
@Chris could you also change mine please to IP.com thank you
Update: Amended to .com
Message 5 of 9
(1,880 Views)
21-10-2015 10:07 AM
It would be IP.plus.com, is that ok?
Message 6 of 9
(1,880 Views)
21-10-2015 2:30 PM
@Chris - Yep that's fine thank you will I need to restart my router and will my gateway change?
Message 7 of 9
(1,880 Views)
21-10-2015 3:19 PM
Nope, you won't need to do anything. It takes around 24 hours to update but I've just put that through now.
Message 8 of 9
(1,880 Views)
21-10-2015 3:35 PM
@Chris - Thank you I'm very grateful
Message 9 of 9
(1,880 Views)
