Capped upload 12mbps?
jt
Hi, can my upload be uncapped from 12mbps back to 20mbps please, thanks.
Fixes: 58
Re: Capped upload 12mbps?
uploads aren't capped - they are up to 20Mb/s on your product
rongtw
Fixes: 12
Unless he has been put on the 55/10
then he would have lost his upload , Op what is your product ?Huh
Fixes: 12
if he was on the 55/10 product his upstream wouldn't currently be 12Mbps
jt
Apparently 20/80, but I get 12/60. I don't see how it was at 20 a few days ago now my upload has lowered, the same has happened with my download, was getting 76mbps now it is stuck at 60mbps...
