Capped at 2.34Mb/s (~300KB/s) after removing Pro addon
hhaddow990
Hi
I recently removed the pro add-on and now my speeds has been crippled
I feel like I am being punished for removing the 5ppm service, is there anything I can do to fix this
Regards
Hector
update I have confirmed it is indeed the pro add-on as I temporarily reactivated it in order to compare results and was getting my usual 7Mb/s (~870MB/s) (note I'm 1.8mi from the green cabinet).
1st image: BTW Speedtest with pro add-on removed
2nd image: BTW Speedtest with pro add-on re-enabled
