Cant get online
Tomra
Cant get online
Hi folks, I believe i've done all the basic stuff to sort my connection but I cant get online. BT openreach have been working in my street all week so I have had some downtime maybe an hour every other day or so. Today however I've not been able to get back online since 1pm. How can I check that I havent been disconnected from the exchange?
6 REPLIES 6
Champnet
Aspiring Hero
Fixes: 12
Re: Cant get online
Is your phone working normally ?
Tomra
Re: Cant get online
Hey. I just plugged my landline in and checked. Defo doesn’t work. No tone. Doesn’t dial out and doesn’t receive calls. Tried on all phone connections and with/without filters/removing the router entirely etc. My thinking is openreach have done something. As I said they have interrupted my connection a few times but it usually comes back on after a few hours but that’s now been since 1pm today
Champnet
Aspiring Hero
Fixes: 12
Re: Cant get online
That’s why you can’t get online. Openreach may be back to correct the problem but in the meantime log it as a fault with your phone supplier.
Tomra
Re: Cant get online
My line is with Plusnet.
Champnet
Aspiring Hero
Fixes: 12
Re: Cant get online
Log it as a fault with Plusnet, they can talk to people you can’t.
Tomra
Re: Cant get online
I think there could be more to this. I can get access to google & YouTube but nothing else. My router has also defaulted to username “setup@plusdsl.net” I think my router has somehow become disassociated from my account. Can this be fixed with a remote fix to push a firmware update to the router. like most I’m working from home and would be grateful if it can be fixed ASAP.
Edit - I seen there was an option to disconnect and after doing that it allows you to Edit these details which fixed my problem
