Cant access any google services
Terranova667
Any one else having problems accessing google services nothing is working for me google search, Youtube,  maps nothing at all will load, other sites are loading just fine so it doesn't appear to be a DNS issue i tried a trace to youtube and it just times out after it reaches plusnets gateway, google.com will complete a trace but the pings are high google.co.uk wont complete at all like youtube.
before i try a gateway hop is this happening for anyone else or just me any ideas.  traces below
Youtube.
Tracing route to youtube.com [212.56.71.187]
over a maximum of 30 hops:
  1    <1 ms    <1 ms    <1 ms  dsldevice.lan [192.168.1.254]
  2    26 ms    12 ms    13 ms  195.166.130.221
  3    17 ms    12 ms    12 ms  link10-central10.pcl-gw02.plus.net [84.93.249.210]
  4    *        *        *    Request timed out.
  5    *        *        *    Request timed out.
  6    *        *        *    Request timed out.
  7    *        *        *    Request timed out.
  8    *        *        *    Request timed out.
  9    *        *        *    Request timed out.
10    *        *        *    Request timed out.
11    *        *        *    Request timed out.
12    *        *        *    Request timed out.
13    *        *        *    Request timed out.
14    *        *        *    Request timed out.
15    *        *        *    Request timed out.
16    *        *        *    Request timed out.
17    *        *        *    Request timed out.
18    *        *        *    Request timed out.
19    *        *        *    Request timed out.
20    *        *        *    Request timed out.
Google.com
Tracing route to google.com [74.125.20.102]
  2    13 ms    12 ms    12 ms  195.166.130.221
  3    12 ms    12 ms    11 ms  link10-central10.pcl-gw02.plus.net [84.93.249.210]
  4    12 ms    11 ms    12 ms  72.14.223.32
  5    13 ms    13 ms    13 ms  72.14.235.75
  6    15 ms    14 ms    13 ms  72.14.239.231
  7    90 ms    90 ms    90 ms  216.239.42.223
  8  105 ms  108 ms  105 ms  209.85.143.115
  9  114 ms  119 ms  114 ms  216.239.40.22
10  126 ms  123 ms  124 ms  216.239.51.97
11  148 ms  148 ms  148 ms  209.85.247.39
12  148 ms  148 ms  148 ms  216.239.46.175
14  149 ms  149 ms  148 ms  pe-in-f102.1e100.net [74.125.20.102]
Google.co.uk
Tracing route to google.co.uk [212.56.71.99]
  1    <1 ms    <1 ms    1 ms  dsldevice.lan [192.168.1.254]
  2    12 ms    12 ms    12 ms  195.166.130.221
  3    36 ms    11 ms    12 ms  link10-central10.pcl-gw02.plus.net [84.93.249.210]
Fixes: 58
Re: Cant access any google services
Terranova667
thanks for that oldjim i'll do a hop and report back
Terranova667
well a Gateway hop seems to have done the trick not sure if it was the Gateway or the Ip address i was given after my phone line issue this morning that caused the issue any way all good now thread can be closed if needs be.
Champnet
Deleted, seems problem solved, also far too slow...........
Plusnet Staff
Plusnet Staff
Fixes: 159
Quote from: Chris
Thanks all, I'm raising a problem to get this looked at. If anyone else sees it then it'd be good to know which gateway you're on and a trace to the site.
 Chris Parr
 Plusnet Staff
cedlor
Maybe not everyone who reads it knows how to find which gateway they are on?
http://usertools.plus.net/@gateway/
Plusnet Staff
Plusnet Staff
Fixes: 159
We can normally see from a tracert, but thanks good point Smiley
 Chris Parr
 Plusnet Staff
Fixes: 58
A tracert is needed because when the problem occurs the usertool gateway checker usually doesn't work
