Cant access any google services
- Re: Cant access any google services
07-11-2015 5:05 PM
Any one else having problems accessing google services nothing is working for me google search, Youtube, maps nothing at all will load, other sites are loading just fine so it doesn't appear to be a DNS issue i tried a trace to youtube and it just times out after it reaches plusnets gateway, google.com will complete a trace but the pings are high google.co.uk wont complete at all like youtube.
before i try a gateway hop is this happening for anyone else or just me any ideas. traces below
Youtube.
Tracing route to youtube.com [212.56.71.187]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms dsldevice.lan [192.168.1.254]
2 26 ms 12 ms 13 ms 195.166.130.221
3 17 ms 12 ms 12 ms link10-central10.pcl-gw02.plus.net [84.93.249.210]
4 * * * Request timed out.
5 * * * Request timed out.
6 * * * Request timed out.
7 * * * Request timed out.
8 * * * Request timed out.
9 * * * Request timed out.
10 * * * Request timed out.
11 * * * Request timed out.
12 * * * Request timed out.
13 * * * Request timed out.
14 * * * Request timed out.
15 * * * Request timed out.
16 * * * Request timed out.
17 * * * Request timed out.
18 * * * Request timed out.
19 * * * Request timed out.
20 * * * Request timed out.
Google.com
Tracing route to google.com [74.125.20.102]
2 13 ms 12 ms 12 ms 195.166.130.221
3 12 ms 12 ms 11 ms link10-central10.pcl-gw02.plus.net [84.93.249.210]
4 12 ms 11 ms 12 ms 72.14.223.32
5 13 ms 13 ms 13 ms 72.14.235.75
6 15 ms 14 ms 13 ms 72.14.239.231
7 90 ms 90 ms 90 ms 216.239.42.223
8 105 ms 108 ms 105 ms 209.85.143.115
9 114 ms 119 ms 114 ms 216.239.40.22
10 126 ms 123 ms 124 ms 216.239.51.97
11 148 ms 148 ms 148 ms 209.85.247.39
12 148 ms 148 ms 148 ms 216.239.46.175
14 149 ms 149 ms 148 ms pe-in-f102.1e100.net [74.125.20.102]
Google.co.uk
Tracing route to google.co.uk [212.56.71.99]
1 <1 ms <1 ms 1 ms dsldevice.lan [192.168.1.254]
2 12 ms 12 ms 12 ms 195.166.130.221
3 36 ms 11 ms 12 ms link10-central10.pcl-gw02.plus.net [84.93.249.210]
Youtube.
Google.com
Google.co.uk
Message 1 of 9
(1,304 Views)
8 REPLIES 8
07-11-2015 5:10 PM
Message 2 of 9
(863 Views)
07-11-2015 5:13 PM
thanks for that oldjim i'll do a hop and report back
Message 3 of 9
(863 Views)
07-11-2015 5:18 PM
well a Gateway hop seems to have done the trick not sure if it was the Gateway or the Ip address i was given after my phone line issue this morning that caused the issue any way all good now thread can be closed if needs be.
Message 4 of 9
(863 Views)
07-11-2015 5:18 PM
Deleted, seems problem solved, also far too slow...........
Message 5 of 9
(863 Views)
10-11-2015 9:06 AM
Quote from: Chris Thanks all, I'm raising a problem to get this looked at. If anyone else sees it then it'd be good to know which gateway you're on and a trace to the site.
Message 6 of 9
(863 Views)
10-11-2015 10:08 AM
Maybe not everyone who reads it knows how to find which gateway they are on?
http://usertools.plus.net/@gateway/
Message 7 of 9
(863 Views)
10-11-2015 10:09 AM
We can normally see from a tracert, but thanks good point
Message 8 of 9
(863 Views)
10-11-2015 10:19 AM
A tracert is needed because when the problem occurs the usertool gateway checker usually doesn't work
Message 9 of 9
(863 Views)
