Cannot use OpenVPN
- Cannot use OpenVPN
Cannot use OpenVPN
29-01-2019 11:29 AM
I need to connect to a VPN (OpenVPN) for work. I have already purchased the static IP add-on and enabled port clamping on the Plusnet Hub One router.
The firewall rule for the VPN now accepts all traffic from my Plusnet IP. However, while I can authenticate and connect to the VPN server, I cannot use the VPN normally. Some traffic seems to be blocked either by the router or by Plusnet.
I tried port forwarding and enabling DMZ for my laptop, but still no luck.
Can someone help me fix this issue?
Message 1 of 2
(952 Views)
1 REPLY 1
Re: Cannot use OpenVPN
29-01-2019 2:25 PM
Message 2 of 2
(924 Views)
