Cannot download via P2P
mattsando
Hello,
My fobre connection is otherwise perfectly fine. However, as of yesterday, I am unable to download anything via P2P (24 hours of the day, peak and off-peak).
I am on an unlimited package and my monthly usage states that I have downloaded 90GB this month.
Is there some sort of traffic shaping in place, or have I got a fault?
bill888
Seasoned Pro
Fixes: 24
Re: Cannot download via P2P
Have you checked your Surf settings in the Member's Centre?
https://portal.plus.net/surf/
mattsando
Yes, I have:
Choose to activate or deactivate Surf
Current Status: Your Surf Access is currently Unrestricted
Fixes: 5
I've checked your account but I cannot see any problems. Your usage stats also don't show any problems.
 Tony T
mattsando
And as if by magic, the P2P files are now downloading. However, I normally receive about 2.1-2.4MbPS but now I'm getting a hundred Kb (if that). is something going on?
Fixes: 5
Nothing that I'm aware of - and I certainly haven't changed anything.
 Tony T
mattsando
OK. Thanks Tony.
What do I need to do to resolve this issue?
Fixes: 167
There are no restrictions on P2P on your account. P2P is tricky to diagnose as a lot of the issues can be caused by the seeding side of things.
Are the files you're trying to download well seeded, have you tried different P2P software?
 Chris Parr
 Plusnet Staff
Fixes: 21
With poor p2p, check several things.
You have an open incoming port, check the router that upnp is running and a port is open. Or setup a static port on the app and match it to the routers one via the open port settings (vary by router, but usually they have a section to open a specific port to a specific ip address internally)
Use canuseeme to check the port is open and the app is connecting.
