Cannot connect to the internet
- Re: Cannot connect to the internet
30-11-2014 11:25 AM
I have a technicolor tg582n as a router. My connection has gone down and i am trying to get back on the internet.
It happened once before but i do not remember how i did it.
The window said to enter my username and password to access my technicolor gateway.
I do enter the ssid name and the key number but it says conne ction failed. Am i using the wrong UN and PW?
I did arrive to get into the router and try there, but it fails and the router is stuck on retry.
My computer says that it is connected though, but if i try to go onthe internet it doesn't work.
What am i doing wrong?
Message 1 of 3
(650 Views)
2 REPLIES 2
30-11-2014 11:27 AM
There seems to be something going on at the moment - worth having a read through here :
http://community.plus.net/forum/index.php/topic,134472.0.html
Message 2 of 3
(341 Views)
30-11-2014 11:56 AM
Locked in favour of existing thread
Message 3 of 3
(341 Views)
