Cannot connect - directed to router setup page
drawstron1
I cannot connect to the Internet, this is a new fibre broadband service from plusnet (activated this week) with new router.  The router is switched on and shows a blue light (ie internet OK) but trying to go to a website redirects to the router setup page or gives an ERR_CONNECTION_RESET error.
I noticed the broadband username is setup@plusdsl.net, not my username
I have tried power cycle, factory reset but still not working
Can anyone help please?
3 REPLIES 3
MatthewWheeler
Fixes: 479
Re: Cannot connect - directed to router setup page
Sorry to hear your connection isn't working.
I've tested your line and it appears that your routers stuck in its automated setup.
Can you try carrying out the steps below to see if they get you online?
1) Open a browser
2) Enter 192.168.1.254 into the address bar
3) On the router's home screen, select 'Settings'
4) Enter the password. This is the 'Admin Password for Hub Manager' on the removable card on the rear of the router (it can also be found on the base of the router)Within the 'Settings' menu, select the 'Broadband' tab or 'Enter your broadband username and password'
5) On the following page, you must enter the broadband username and password (There is a 'show characters option on this page if you are struggling with entering the password)
6) Click the 'Connect' button. The power light should turn blue to indicate that there is an internet connection.
Let us know how you get on
 Matthew Wheeler
drawstron1
Matthew, thanks for your reply, I followed the steps and it is all working now
Dumbledore
Fixes: 34
Hello @drawstron1
I am pleased to hear everything has now been resolved.
Should you require any further assistance, please do get back in touch with us.
Kind regards,
- Wakas
