Cannot access https://www.tylertech.com/
FIXED- Subscribe to RSS Feed
- Cannot access https://www.tylertech.com/
19-06-2018 10:46 AM - edited 19-06-2018 10:48 AM
Howdy, I am hoping I can get someone from PlusNet to check this out. I cannot access https://www.tylertech.com/.
I can access this domain if I am connected via a VPN or any other network (ie mobile) but not when exclusively connected via plusnet fibre.
This is not a DNS issue as it does resolve down to the ip address as it should, it's a routing problem the plus.net network. Help!
Thanks,
R
Fixed! Go to the fix.
Re: Cannot access https://www.tylertech.com/
19-06-2018 10:52 AM
Can you post a tracert log (if using a PC) or a traceroute (if a Mac).
It may be out of PlusNet's control if outside their systems, but that will help to identify where the problem is.
19-06-2018 10:56 AM - edited 19-06-2018 10:58 AM
My money would be on it being another geolocation problem. See here. https://community.plus.net/t5/Broadband/NGT-App-being-blocked-on-broadband-connection/m-p/1546375#M3...
19-06-2018 10:58 AM
Thanks @Baldrick1
Didn't think of that, but I suspect you may be right.
19-06-2018 11:10 AM - edited 19-06-2018 11:13 AM
I have a static ip address but this issue only happened after I switched from BT to PlusNet. I've just been getting around it when I need to with TunnelBear hehe, which is a pain because it's slooooow.
It could very well be a geolocation problem but the company I am connecting to is American (American Expat) I don't know if the issue is on my works domain or something with plusnet. I have a ticket in with my office IT as well.
C:\WINDOWS\system32>tracert www.tylertech.com Tracing route to tylertech.com [207.182.208.157] over a maximum of 30 hops: 1 2 ms 2 ms 1 ms ARCHER_VR400 [192.168.1.1] 2 11 ms 10 ms 10 ms 410.xe-2-2-0.central10.pcn-bng03.plus.net [84.93.253.80] 3 10 ms 10 ms 10 ms 411.be7.pcn-ir01.plus.net [84.93.253.83] 4 10 ms 10 ms 11 ms core1-BE1.colindale.ukcore.bt.net [195.99.125.132] 5 12 ms 12 ms 13 ms peer6-hu0-6-0-2.telehouse.ukcore.bt.net [62.172.103.13] 6 11 ms 11 ms 11 ms t2c3-et-7-1-0-0.uk-lon1.eu.bt.net [166.49.211.228] 7 12 ms 12 ms 11 ms ldn-b1-link.telia.net [213.248.97.48] 8 88 ms 86 ms 92 ms ldn-bb4-link.telia.net [62.115.143.26] 9 87 ms 86 ms 86 ms ash-bb4-link.telia.net [62.115.122.61] 10 86 ms 86 ms 87 ms ash-b1-link.telia.net [213.155.136.39] 11 91 ms 93 ms 93 ms 192.205.33.25 12 89 ms 89 ms 89 ms cr82.wshdc.ip.att.net [12.122.135.102] 13 97 ms 98 ms 94 ms cr2.wswdc.ip.att.net [12.122.134.94] 14 97 ms 93 ms 94 ms cr2.n54ny.ip.att.net [12.122.28.41] 15 92 ms 93 ms 93 ms cr1.cb1ma.ip.att.net [12.122.28.134] 16 98 ms 94 ms 93 ms 12.122.145.73 17 93 ms 95 ms 93 ms 12.94.2.138 18 * * * Request timed out. 19 * * * Request timed out. 20 * * * Request timed out. 21 * * * Request timed out. 22 * * * Request timed out. 23 * * * Request timed out. 24 * * * Request timed out. 25 * * * Request timed out. 26 * * * Request timed out. 27 * * * Request timed out. 28 * * * Request timed out. 29 * * * Request timed out. 30 * * * Request timed out. Trace complete.
19-06-2018 11:31 AM
Now here's a funny variation on geolocation problems. If I set my Windscribe destination to UK it won't give me access. If I change my location to USA I get the log in page.
So this site appears to only accept US IP Addresses!
19-06-2018 1:17 PM
19-06-2018 2:37 PM
That's what I was thinking with my limited testing. Our IT department is fairly useless.
19-06-2018 3:10 PM
If in the meantime you need access then download a free VPN browser extension. I use Windscribe for Chrome, this doesn't give any significant difference in download speed.. If you register you get 10GB per month free. Setting the destination to USA will give you access.
19-06-2018 3:15 PM
Let us know how you get on with what @Baldrick1 suggests @RHines - unfortunately that (or something of that ilk) seems to be the only work around as far as i can see.
Hope you managed to find something that works.
19-06-2018 3:16 PM - edited 19-06-2018 3:17 PM
I already have a VPN service (Tunnelbear mentioned in OP), that's the only way I can access the site and services. Thanks though. I have a ticket in with corporate.
19-06-2018 3:35 PM
As it worked fine with BT, and I can confirm the link takes me to a login screen from my EE Broadband, I should push PN for further investigation. Clearly they are blocking it somewhere in their part of the network. The VPN bypassed their network routing.
19-06-2018 3:38 PM
They could be yes, or my office backbone provider could be blocking this ip address for some reason. It does get as far as ATT in america before it drops off.
19-06-2018 3:49 PM - edited 19-06-2018 3:50 PM
So if the reason is that my VPN is bypassing the Plusnet network routing then why can I access it if I set the VPN destination to USA but not if I set the VPN destination to UK?
The reason I suggested Windscribe as a temporary measure was because you were complaining that your VPN slows things down.
19-06-2018 3:55 PM - edited 19-06-2018 4:02 PM
I thought I had tested this before but I don't remember if it worked. I just tested it again and It does work if I tunnel from/to the UK. So it's probably not geolocation blocking. Great suggestion. I've tested a few other countries just for fun and they all work fine.
So it's either an issue with routing or maybe they've blocked this ip address or a block of them for some reason?
