Can you use a Belkin play n600 db with plusnet fibre?
duncansaul
We have been having problems with speed & loosing connection, spoke to someone at plusnet advised we could try changing modem & router as quite old.  bought a Belkin play n600 db, but cannot connect it up.  its either showing limited connectivity or no connectivity. we are total tech idiots, can anyone advise how you go from a separate modem & router to one that is combined. Help!!!!  Cry Undecided Sad
1 REPLY
Den1
Re: Can you use a Belkin play n600 db with plusnet fibre?
The router you have bought is just a router you will still need the openreach modem to connect it to  Wink  it should be a simple case of inputting your plusnet details into the router and of you go
I use one of these as on all in one solution http://www.amazon.co.uk/TP-LINK-TD-W9980-Wireless-Gigabit-300Mbps/dp/B00NEQZ12Y/ref=sr_1_1?s=compute...
