Can the Plusnet Hub One be put into Bridge mode
BobRegis
I am looking to ditch the Plusnet Hub One as it keeps dropping my Wifi signal and seems rubbish at managing the LAN connection.
I have looked at the wireless settings but can not for the life of me see where I can put this into bridge mode so that I can use my trusty router.
Fixes: 154
Re: Can the Plusnet Hub One be put into Bridge mode
I don't believe it can.
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
Fixes: 31
Switch Wi-Fi off on the hub1 and set your other router, or the hub1 to use a different ip address range other than 192 and so on, plug your working rounter into the gig port of the hub1 should sort you out.
mlavende
I'm hoping to use my Asus router in the same way when my fibre is installed soon.
Currently my Asus uses 192.168.2.xxx and I understand the hub1 uses 192.168.1.xxx. Are they different enough or do I really need to change from 192 to something else? That would be a bit of a pain.
-Mat
BobRegis
Thanks.
When I log into my router and then go to Advanced settings, IP addresses I see the following with the first already selected:
DHCP Network Range
192.168.1.64 - 192.168.1.253 (Default)
172.16.0.64 - 172.16.255.254
Configure manually
Should I select the middle option and then would I be good to go?
Alternatively is their a dirt cheap cable modem that I could buy (I don't have one of those Openreach modems that everyone else seems to have)?
Fixes: 31
If you use the 172 range you should be fine.
