Can the Plusnet Hub One be put into Bridge mode
- Can the Plusnet Hub One be put into Bridge mode
31-12-2015 9:19 PM
I am looking to ditch the Plusnet Hub One as it keeps dropping my Wifi signal and seems rubbish at managing the LAN connection.
I have looked at the wireless settings but can not for the life of me see where I can put this into bridge mode so that I can use my trusty router.
Message 1 of 6
(3,370 Views)
5 REPLIES 5
Re: Can the Plusnet Hub One be put into Bridge mode
31-12-2015 9:23 PM
I don't believe it can.
Message 2 of 6
(2,350 Views)
01-01-2016 1:37 AM
Switch Wi-Fi off on the hub1 and set your other router, or the hub1 to use a different ip address range other than 192 and so on, plug your working rounter into the gig port of the hub1 should sort you out.
Message 3 of 6
(2,350 Views)
02-01-2016 10:36 AM
I'm hoping to use my Asus router in the same way when my fibre is installed soon.
Currently my Asus uses 192.168.2.xxx and I understand the hub1 uses 192.168.1.xxx. Are they different enough or do I really need to change from 192 to something else? That would be a bit of a pain.
-Mat
-Mat
Message 4 of 6
(2,350 Views)
03-01-2016 2:01 PM
Thanks.
When I log into my router and then go to Advanced settings, IP addresses I see the following with the first already selected:
DHCP Network Range
192.168.1.64 - 192.168.1.253 (Default)
172.16.0.64 - 172.16.255.254
Configure manually
Should I select the middle option and then would I be good to go?
Alternatively is their a dirt cheap cable modem that I could buy (I don't have one of those Openreach modems that everyone else seems to have)?
DHCP Network Range
Configure manually
Message 5 of 6
(2,350 Views)
03-01-2016 2:09 PM
If you use the 172 range you should be fine.
Message 6 of 6
(2,350 Views)
