Can't seem to view ANY broadband usage statistics
- Can't seem to view ANY broadband usage statistics
14-04-2017 5:28 PM
I'm trying to view how much I've downloaded over the last few months, but the 'View My usage' just reports it has been reset.
Is there anything I'm missing as I've been using the fibre broadband for a couple of years now so there should be something I can monitor
Message 1 of 3
(608 Views)
2 REPLIES 2
Re: Can't seem to view ANY broadband usage statistics
14-04-2017 6:01 PM
The 'view my usage' isn't working, there are multiple threads on this I believe.
You can either download a monitoring tool or if you have a hub one that will show you the data transferred since the last time you connected under 'helpdesk'.
Message 2 of 3
(598 Views)
14-04-2017 6:41 PM
I haven't got a hub one, they won't give me one!
Message 3 of 3
(585 Views)
