Can't find Handy Reference Card in router box
petermsgodfrey
I have received and set up my router. The Let's Get Connected booklet says the box should contain a 'Handy reference card' containing the Hub Wireless settings. Can anyone tell me where it should be in the box ?
4 REPLIES 4
Browni
Aspiring Hero
Fixes: 49
Re: Can't find Handy Reference Card in router box
You'll find it slotted into the back of the router.
I must have been really bad in a previous life as this was my 3rd ISP in a row that used lithium.
Now you're stuck with me because my new ISP doesn't run a forum Cheesy
Fixes: 7
The card may already be inserted in the slot, at the back of the router ?
Regards
Mike
Mike
petermsgodfrey
Spot on - thanks!
petermsgodfrey
Thanks - I have it now!
