Can’t access any websites
- Can’t access any websites
- « Previous
- 1
- 2
- Next »
Re: Can’t access any websites
04-03-2021 9:38 PM
OK, was just a thought. My next question then is - is the user name in the router yours, or is it 'setup@plusdsl.net'?
04-03-2021 9:39 PM
04-03-2021 9:41 PM
When it comes back, please check.
04-03-2021 9:44 PM
04-03-2021 9:49 PM
That explains it - you need to replace that with the same user name and password you had in the old one.
04-03-2021 9:50 PM
04-03-2021 10:01 PM
You mean you didn't note it down ? it is probably the most important information you need. Have you ever logged into your Members Centre? - that is the same information which you need to enter.
04-03-2021 10:03 PM
04-03-2021 10:05 PM
OK, so replace the 'setup' with the username you log into the account, and enter the password associated with that.
04-03-2021 10:15 PM
Dont forget to add @plusdsl.net after your username.
04-03-2021 10:17 PM
Good point, @Mustrum - I forgot that bit, it's quite a while since I set this one up.
- « Previous
- 1
- 2
- Next »
