Can’t access any websites
- Re: Can’t access any websites
04-03-2021 8:55 PM
04-03-2021 9:06 PM
@joshhoffmann Welcome to the forums. If your 'go live' date was today, it can take up to midnight for all the systems to integrate. I'd check back tomorrow, and post back if you are still having issues.
04-03-2021 9:12 PM
04-03-2021 9:15 PM - edited 04-03-2021 9:16 PM
Then if your situation is exactly the same, @Kirstie86 , the same comment applies.
04-03-2021 9:16 PM
04-03-2021 9:17 PM
04-03-2021 9:17 PM - edited 04-03-2021 9:18 PM
@joshhoffmann that is because, as I said, not all the systems will be fully integrated,
04-03-2021 9:20 PM
So your situation is totally different, @Kirstie86 . Are you on ADSL or Fibre and which router do you have?
04-03-2021 9:21 PM
04-03-2021 9:24 PM
@Kirstie86 OK. So the first question is - what colour are your lights? Please note, I am not a network expert, and I have never seen a Hub One, but if you bear with me and answer my seemingly stupid questions, I will try to help.
04-03-2021 9:25 PM
04-03-2021 9:27 PM
Okay, that is a start. If you log into the router and check its connection status, what does it say?
04-03-2021 9:30 PM
04-03-2021 9:32 PM
This may sound stupid, but are you actually connected to that router, or still your old one?
04-03-2021 9:35 PM
