Can’t access any websites
joshhoffmann
Hi, I’ve just had my plusnet broadband activated, my router is displaying a stable blue light but yet I cannot access any websites or login to any programs on my computer that require internet access.
25 REPLIES 25
Legend
Fixes: 254
Re: Can’t access any websites
@joshhoffmann Welcome to the forums. If your 'go live' date was today, it can take up to midnight for all the systems to integrate. I'd check back tomorrow, and post back if you are still having issues.
Kirstie86
I am having the same problem
Legend
Fixes: 254
Then if your situation is exactly the same, @Kirstie86 , the same comment applies.
joshhoffmann
Potentially worth mentioning, every website is returning ERR_FAILED or ERR_CONNECTION_RESET errors
Kirstie86
I been with plusnet 8 years just had a new hub send as last one witch I had for 6 years packed up they said just plug it in and away I go
Legend
Fixes: 254
@joshhoffmann that is because, as I said, not all the systems will be fully integrated,
Legend
Fixes: 254
So your situation is totally different, @Kirstie86 . Are you on ADSL or Fibre and which router do you have?
Kirstie86
Plusnet fiber extra and got the plusnet hub one
Legend
Fixes: 254
@Kirstie86 OK. So the first question is - what colour are your lights? Please note, I am not a network expert, and I have never seen a Hub One, but if you bear with me and answer my seemingly stupid questions, I will try to help.
Kirstie86
The light is blue
Legend
Fixes: 254
Okay, that is a start. If you log into the router and check its connection status, what does it say?
Kirstie86
Connected at the moment but it will come up with no connection in about 2 mons time
Legend
Fixes: 254
This may sound stupid, but are you actually connected to that router, or still your old one?
Kirstie86
No connected to the new one
