Can someone please fix my crazy profile!
Doglet
I ordered Fibre Extra 80/20 January, they stuck me on ADSL 20/1 for the first couple of weeks, ever since Fibre went live, it's been like 20/20. It's like I have ADSL download and Fibre Upload! But today (3:30am) it's just crazy bad! Crazy 5392395651
1. Product name:	Plusnet Hub
2. Serial number:	+081441+NQ52925168
3. Firmware version:	Software version 4.7.5.1.83.8.217 Last updated Unknown
4. Board version:	Plusnet Hub One
5. DSL uptime:	24 days, 08:35:35
6. Data rate:	19999 / 79906
7. Maximum data rate:	25934 / 81284
8. Noise margin:	14.2 / 6.7
9. Line attenuation:	15.6 / 14.1
10. Signal attenuation:	16.0 / 14.1
11. Data sent/received:	24.3 GB / 228.7 GB
12. Broadband username:	Username@plusdsl.net
13. 2.4 GHz Wireless network/SSID:	PLUSNET-RZGN
14. 2.4 GHz Wireless connections:	Enabled (802.11 b/g/n (up to 144 Mb/s))
15. 2.4 GHz Wireless security:	WPA2
16. 2.4 GHz Wireless channel:	Automatic (Smart Wireless)
17. 5 GHz Wireless network/SSID:	PLUSNET-RZGN
18. 5 GHz Wireless connections:	Enabled (802.11 a/n/ac (up to 1300 Mb/s))
19. 5 GHz Wireless security:	WPA2
20. 5 GHz Wireless channel:	Automatic (Smart Wireless)
21. Firewall:	Default
22. MAC Address:	a0:1b:29:66:5a:f6
23. Modulation:	G.993.2 Annex B
24. Software variant:	AA
25. Boot loader:	1.0.0
Estimated line speed:
    8Mb (This may vary between 5.5Mb and 12.5Mb) - Checked on 2016-05-08 01:56:15
Current line speed:
    21 Mb
4 REPLIES 4
Gus
Re: Can someone please fix my crazy profile!
http://speedtest.btwholesale.com/ run further testing and see what profile BT has you on
Then check on the PN portal after login, https://portal.plus.net/my.html?action=data_transfer_speed
Then report what you get to an agent via phone/online chat and that should start the ball back to rolling
Unvalued customer since 2001 funding cheap internet for others / DSL/Fibre house move 24 month regrade from 8th May 2017
Den1
Needs a kick from plusnets end, you are syncing at the max rate
Have you tried dropping the connection and then reconnecting ?
HarryB
Fixes: 256
Leave that with me, I'll get it sorted.
The accounts actually showing as an ADSL account (Due to issues during signup)
I'll drop you a notification via the account once it's fixed.
 Harry Beesley
nigelmercier
4. Board version:	Plusnet Hub One ...
How does one get this data?
[EDIT] Found it. Helpdesk page under Troubleshooting on the router
