Can someone check my stats please.
- Can someone check my stats please.
- « Previous
- Next »
Re: Can someone check my stats please.
22-04-2019 2:56 PM
Hi @Alucidnation, looking over the connection, the profile on our suppliers side has been the full 80Mbps down and 20Mbps up for a while now. I see Dave appears to have bumped up the connection profile on our side, however I don't believe this should have any affect as your on a dynamic IP.
It does look like the sync speed has dropped by a couple of Mbps at the time of testing today, however I can't see anything pointing towards why this may have been, although it may just be a blip.
22-04-2019 3:53 PM
It does seem odd as my router is connecting at 67000 exactly.
I did try a couple of reboots earlier and although the attainable has changed slightly on each one, my connection won’t budge at 67.
I’ll keep an eye on it over the next few days.
22-04-2019 4:12 PM
Hopefully it is just a blip and nothing to worry about, however do let us know if it continues to deteriorate.
Having said this, the download speed seems to be very much in line with the top end of the estimates of 46.9Mbps - 67.3Mbps.
22-04-2019 4:43 PM
Yes indeed it is, which is why I wondered if dlm had kicked in and banded me at 67?
22-04-2019 4:55 PM
22-04-2019 6:09 PM
- « Previous
- Next »
