Can someone check my stats please.
Jubby
All Star
Fixes: 31
Re: Can someone check my stats please.
Hi @Alucidnation,
Thank you for updating the ticket.
To keep this conversation streamline, I have updated the fault ticket on your account with a detailed reply. When you have replied to the ticket, please reply on here so we can pick it up as soon as possible for you.
Thank you.
 Lewis G
 Infrastructure Operations Professional
Alucidnation
Apologies, had a house full.
Ticket updated.
Alucidnation
Speeds have now dropped below minimum.
MatthewWheeler
Fixes: 479
Sorry to hear that.
I'll get the ticket updated for you shortly
 Matthew Wheeler
Alucidnation
Thanks.
I have replied to the ticket update.
MatthewWheeler
Fixes: 479
Thanks.
I'll get that picked up shortly
 Matthew Wheeler
Alucidnation
Thanks.
Ticket replied to.
A bit confused on the time of the appointment.
MatthewWheeler
Fixes: 479
Apologies that's what a 7:30am start and lack of coffee does to you!
I've just updated the ticket with the correct appointment
 Matthew Wheeler
Alucidnation
No problem.
Thanks.
Ill update when the engineer has been.
Alucidnation
ticket updated.
adamwalker
Fixes: 221
Cheers, I can see someone is due to chase the fault up with our suppliers today so we'll have a further update for you soon.
 Adam Walker
Alucidnation
Yes, just spoken to Matthew.
I have also just updated the ticket with more info
Fixes: 1,600
Thanks, I've tested your line and I can see your router in sync at 51.7mbps. As this is now within the estimates we'd struggle to get our suppliers to investigate this further as it's likely another engineer would just pass the job back as right when tested.
It's possible your speeds have dropped from where you had them previously due to cross talk which is basically interference from other connections in the cabinet as other people in the neighbourhood move on to fibre.
I'd recommend keeping an eye on this and let us know if your speeds drop further.
Alucidnation
Ticket updated.
Fixes: 1,600
I can see you've since spoken with someone.
