Can someone check my connection please
- Can someone check my connection please
18-05-2017 3:25 PM - edited 18-05-2017 3:31 PM
My connection was feeling very slugging while gaming, just wondering why.
Re: Can someone check my connection please
18-05-2017 3:42 PM
Hey St3
Testing your line isn't identifying any problems...
Test Outcome | Pass |
Test Outcome Code | GTC_FTTC_SERVICE_0003 |
Description | No problem found, OAM test is not currently supported on this line. |
Main Fault Location | OK |
Sync Status | In Sync |
Downstream Speed | 73.2 Mbps |
Upstream Speed | 20.0 Mbps |
Appointment Required | N |
Fault Report Advised | N |
NTE Power Status | PowerOn |
Voice Line Test Result | Pass |
Bridge Tap | Not Detected |
Radio Frequency Ingress | Not Detected |
Repetitive Electrical Impulse Noise | Not Detected |
Cross Talk | Not Detected |
Estimated Line Length In Metres | 410.7 |
Upstream Rate Assessment | Very Good |
Downstream Rate Assessment | Very Good |
Interference Pattern | Regular Interference Observed Daily |
Service Impact | No Impact Observed |
Interference Duration Longest Occurrence | ; 00:00 to 23:45 |
Interference Location | Customer Premise |
Interference Observed In Days | 14 |
Home Wiring Problem | Not Detected |
Downstream Policing Discard Rate | 0.0 |
Customer Traffic Level | Upstream and Downstream Traffic Detected |
Technology | VDSL |
Profile Name | 0.128M-80M Downstream 3dB, Retransmission High - 0.128M-20M Upstream, Error Protection Off |
Are you using a wireless or wired connection?
18-05-2017 4:10 PM - edited 18-05-2017 4:13 PM
@St3 does your connection suffer ? buffering etc slow pages
i presume you still have the ASUS router , and what gateway you on ?? i still keep getting odd tests but PN can not find problem yet
this is what it shoud be
18-05-2017 8:46 PM
@Gandalf Thanks for checking it over, im using wired i just seam to be getting abit of slow down in gaming. I will keep an eye on it.
@rongtw Yes im still using asus router not had any issues tbh, the first screenshot you added is alot like the tests ive been getting... ive no idea why. Maybe a bad router update or ????
I was playing rocket league tonight and the guys i was playing with said i was moving really slow in game, i also felt like i was hardly moving. So i ran the speedtest which gave me just lower speeds than i normally get but that should not have made my in game gaming slow.
As you said @rongtw the speedtest results should show a steady line but like yours mine are all over the place.
19-05-2017 9:50 AM
19-05-2017 10:41 AM
@St3 i dont have Rocket league , but i do get the same results as you on BF 1 or 4 ?
But we are unable to pinpoint the problem
19-05-2017 8:08 PM - edited 19-05-2017 9:51 PM
Can someone test my line as well? Im ex bt customer. WIth bt i had hh5 sync@ downstream 79990kbs. After i switch to plusnet was 73000kbs but now i have 69511kbs. Im using my bt home hub 5.Is there any problem with my line i should change to plusnet hub ?
EDIT After reboot its sync with downstream @72948kbs
20-05-2017 9:25 AM
@yonasz Our suppliers systems are down for maintenance until 5pm so I can't look into this at the moment but I'll test your line when they're back up and running.
20-05-2017 10:35 AM
@MatthewWheeler Ive only noticed it in Rocket league and battlegrounds in the past week, i can play but im much slower moving that others and my ping seams to be fine when ive noticed this.. ill keep an eye on it.
