Can someone check how often my connection is dropping?
zel
Thanks.
bluewhale
Re: Can someone check how often my connection is dropping?
fyi if you are using the plusnet hub one in vdsl mode, ie direct to the socket the troubleshooting page/ event log/ WAN selection
shows you the connects/disconnects ( 192.168.1.254 )
also this app if you leave running will show things http://www.vwlowen.co.uk/RouterStatsHub/routerstatshub.htm
Fixes: 162
I can take a look, can you PM me your account username please.
 Chris Parr
 Plusnet Staff
