Can lines improve?
dnpark38
Can lines improve?
I'm in the north and the Global Speed tester as always connected to Sheffield server for tests but last week it started to select London giving the same speed results, well slightly higher if anything nothing to shout about.
This morning is still London but speeds have gone up over 2 Mbs, so can lines improve?
I can't recall anyone reporting here speeds suddenly going up always speed drops.
http://www.thinkbroadband.com/speedtest/button/1476198475230638155-mini.png
Fixes: 6
Re: Can lines improve?
dnpark38
I know there are 2 types of BT Cabinet/Modem and I thought only one make was getting that and I know I have the make that wasn't.
Assuming I'm wrong is there any reporting link that will confirm please?
AshPowell
2Mb on Speedtest could be the server youre downloading from.. some I've even had a 10Mb difference.. You can select server manually rather than auto to test this.
Your IP profile could have also been raised if your line has been in good condition over previous.. or G.INP as npr said.
There's a post on kitz website on how to find out your cabinet type.. you enter your postcode or something and it gives you all the ones in your area, you find the one on your road and it tells you the type.. ie broadcom/eci. I'll link you up after work when I find it
dnpark38
From what I recall IP Profile reported on the BT line tester is higher than it was.
SpendLessTime
Aspiring Hero
Fixes: 82
You may have also had a change of gateway. This alone can increase/decrease speed by a large amount especially if you speed test at peak hour (8pm-11pm). I've lost 40Mbps on some gateways at 8pm compared to a 9am test!
You can find out which gateway you are currently on at http://usertools.plus.net/@gateway/
Fixes: 6
Quote from: dnpark38
I know there are 2 types of BT Cabinet/Modem and I thought only one make was getting that.
There's no reports of ECI cabinets getting G.INP yet.
Estragon
@AshPowell
People aren't always connected to the obvious cabinet, and most don't have one on their road Smiley.
The best check is the BT Wholesale speed estimator, using the phone number, which gives the (phone) cabinet number on the line above the estimate. If there isn't a number it generally means it's an EO line.
For this purpose the Address checker can be dodgy, and the Postcode checker downright unsafe to use.  (A postcode can be served by several cabinets and only one of them is reported). FTTC cabinets are not numbered but are close to their PCP. Normally within 50 metres.
This page has pictures on the Huawei and ECI cabinets, (128s are actually 96s), but doesn't include the newish combo cabinets being used to convert EO lines in some places - particularly BDUK areas.
dnpark38
dnpark38
Keeping up
