Can i get fibre broadband?
- Re: Can i get fibre broadband?
18-01-2018 4:43 PM - edited 18-01-2018 5:41 PM
18-01-2018 5:18 PM
Well it says its available,
and as you have asked to upgrade you have committed yourself.
PN possibly will let you back out but you will have to formally ask.
18-01-2018 5:30 PM
18-01-2018 5:34 PM
Well you won't know the actual speed until the fibre broadband is working,
until that time it is a educated guess.
18-01-2018 5:38 PM
18-01-2018 6:48 PM
The DSL Checker results give 2 figures for FTTC - one for a good line (A) and one for a poor line (B).
Assuming you have a good line you should get between 35.6 and 50.9 on downloads.
Uploads should be between 5.7 and 8.3
The hand back threshold is the minimum you should receive - below this and OpenReach will investigate faults and accept cancellation if they can't get to this speed (I believe).
18-01-2018 7:00 PM
Moderator's note:
Moved to appropriate board.
Forum Moderator and Customer
18-01-2018 7:17 PM
18-01-2018 11:26 PM
Market B has nothing to do with your estimated line speeds, it is your exchange classification, Market B is better than Market A which has an additional cost for no justifiable reason as far a FTTC is concerned.
19-01-2018 2:19 AM
