Can I use my own router?
- Re: Can I use my own router?
20-10-2014 4:44 PM
I'm aware of the fact that you can always disable routing features via telnet on the plusnet device, but given that we also need BT's VDSL modem, this would add up to 3 devices for a "simple" home broadband access.
Would it be possible to not use the plusnet modem at all, and connect my own wireless router to the BT one?
The answer is probably no, but I wanted to double check just in case...
Mario.
Mario.
Message 1 of 9
(2,395 Views)
8 REPLIES 8
20-10-2014 4:51 PM
yes you can use your own router with no problems
Message 2 of 9
(1,348 Views)
20-10-2014 4:52 PM
You can use anything that can connect over PPPoE (which is what the OpenReach modem presents to the Plusnet supplied router).
Message 3 of 9
(1,348 Views)
20-10-2014 5:01 PM
You can even use a combo router/modem if you buy one, but you will need to keep the BT modem if a fault has to be reported as BT won't accept 3rd party combo fibre modem/routers during a fault visit and blame your equipment
FTTP 500 regrade from Tues 28th November
Message 4 of 9
(1,348 Views)
20-10-2014 7:21 PM
Thanks everyone!
I just tried my airport extreme and it worked indeed! That's great news, it's a lot better than having to enable bridge mode via telnet
Cheers,
Mario.
Cheers,
Mario.
Message 5 of 9
(1,348 Views)
20-10-2014 9:04 PM
Wow - that airport is a VERY expensive router.
Message 6 of 9
(1,348 Views)
21-10-2014 7:47 AM
but it's got an apple logo on it, thus the price is justified by those of a certain type.
Message 7 of 9
(1,348 Views)
21-10-2014 5:22 PM
It's expensive indeed, but I didn't really buy it for its routing capabilities, but rather for storage and backups (it's got a 2TB HDD builtin). It obviously also makes an excellent wifi ac router.
It's also very Apple friendly in terms of interacting with other devices. For instance it can wake up a sleeping mac when attempting a connection to your mac at home from the outside.
Anyway, if you have a couple of Apple devices and you are going to use all of its features the price is more than justified. As a standalone router it makes no sense.
Message 8 of 9
(1,348 Views)
22-10-2014 11:30 PM
Ah - ok
Built in NAS drive does make it better VFM.
Message 9 of 9
(1,348 Views)
