Can I use a Belkin F5D8631 Router with PN Fibre ADSL?
flyhighajw
and if I can - is there a guide anywhere on how to do it?
I am on the Plusnet Fibre service getting 76MB according to the latest speed test so very pleased about that.
Thanks in advance.
Fixes: 385
Re: Can I use a Belkin F5D8631 Router with PN Fibre ADSL?
looks like the Belkin F5D8631 is an ADSL modem / router so you won't be able to use it.
Fibre is VDSL so you'd either need an all in one VDSL modem / router or a router with a wan port to connect to the bt modem.
My Broadband Ping - PN-Fibre
flyhighajw
Thank you very much - that is all I needed to hear.
Most grateful.
