Cabling advice needed - locating Hub on different floor to master socket.
- Cabling advice needed - locating Hub on different ...
- « Previous
- 1
- 2
- Next »
Re: Cabling advice needed - locating Hub on different floor to master socket.
09-01-2018 2:26 PM
Knew equipment wasn't my strong point!!!
Using a second router as an access point / Ethernet switch is potentially both the cheapest and neatest solution. Only one box / power socket required downstairs.
09-01-2018 2:26 PM
Yes @Baldrick1 Its an elderly WAP model, but cheap ! And if it does the job then the OP can look for something newer.
I agree another hub one would work but we'd probably need to help him set it up - The Netgear is relatively simple.
09-01-2018 2:51 PM - edited 09-01-2018 2:52 PM
There's a Hub One currently on Ebay at a buy it now price of £14.95. And what's wrong with helping set it up if necessary. The instructions on my link look simple to follow.
- « Previous
- 1
- 2
- Next »
