Cabinet finally being enabled. Maybe.
- Re: Cabinet finally being enabled. Maybe.
20-03-2015 6:11 PM
Plusnet - are you able to check when you would be able to provide fibre to cabinet P19 on the Pontypool exchange? I only recently signed up with Plusnet so when fibre is available what would be the proces and cost) of upgrading from ADSL to fibre?
Hoping sooner rather than later
20-03-2015 6:16 PM
I believe Plusnet now email you when your cabinet goes live, so you can place an order straight away. The upgrade process is very straightforward.
20-03-2015 6:31 PM
Great news!
It looks like that you can get fibre broadband straightaway with predicted speeds of up to 70Mbps (FTTC).
You are connected to cabinet number 19 on the Pontypool exchange.
The Bt infinity site says its not available at all. The info has only been updated in the last few days so im guessing the new dates havent been updated across the board but I'm not sure who to believe. Since I've just signed up to Plusnet (and have a contact) I thought they would be the best people to ask. Is the info on dslchecker generally the most accurate?
20-03-2015 10:33 PM
So the Superfast Cymru site is a bit misleading as I think it's referring to more your exchange being enabled. The actual cabinet does not look to be live yet.
The DSL Checker I posted contains the bulk data from Openreach and this is what ISPs use to gauge availability of a product. It's the same data that's used for when you enter you address or number for availability on any ISP's site.
21-03-2015 8:08 PM
21-03-2015 8:10 PM
23-03-2015 8:46 AM
23-03-2015 9:00 AM
23-03-2015 9:18 AM
23-03-2015 10:53 AM
I see you've already been through the upgrade process
