CS response requested: Poor performance after Test3
HughPH
Hello,
  This evening we noticed our broadband running poorly. The SamKnows box shows that it's been running below 16Mbps since around 18:00 (sync is ~25000Kbps)
  BT's Test3 shows that our profile is similar to our sync, but says that the connection is under-performing - and reports the same sort of speed as SamKnows.
  We are not in the SouthWest or Wales.
5 REPLIES 5
HughPH
Re: CS response requested: Poor performance after Test3
At the moment it's "got better" but I'll update in the morning...
Fixes: 167
I can't see any obvious issues with your line, if you continue to experience problems it's worth reporting a fault at https://faults.plus.net
Not sure what relevance this has?
 Chris Parr
 Plusnet Staff
Fixes: 6
Quote from: Chris
See MBORC Declaration - UPDATE
http://www.plus.net/supportpages.html?a=2&support_action=messages&ispservice_id=adsldial
Fixes: 167
Ah, thanks.
FYI an MBORC doesn't mean that if you're in that area you're going to have a fault, it's there as a note that if you do experience a problem that needs reporting to Openreach it may take longer than usual to resolve.
 Chris Parr
 Plusnet Staff
HughPH
It's happening again, started about 18:00 and has been getting worse since then.
I'll raise it at the link supplied, thanks Chris - and thanks for the MBORC information.
