CS response requested: Poor performance after Test3
- Re: CS response requested: Poor performance after ...
23-02-2016 10:15 PM
Hello,
This evening we noticed our broadband running poorly. The SamKnows box shows that it's been running below 16Mbps since around 18:00 (sync is ~25000Kbps)
BT's Test3 shows that our profile is similar to our sync, but says that the connection is under-performing - and reports the same sort of speed as SamKnows.
We are not in the SouthWest or Wales.
Message 1 of 6
(898 Views)
5 REPLIES 5
Re: CS response requested: Poor performance after Test3
23-02-2016 10:43 PM
At the moment it's "got better" but I'll update in the morning...
Message 2 of 6
(615 Views)
24-02-2016 9:03 AM
I can't see any obvious issues with your line, if you continue to experience problems it's worth reporting a fault at https://faults.plus.net
Not sure what relevance this has?
Quote We are not in the SouthWest or Wales.
Message 3 of 6
(615 Views)
24-02-2016 9:55 AM
Quote from: Chris
See MBORC Declaration - UPDATE
http://www.plus.net/supportpages.html?a=2&support_action=messages&ispservice_id=adsldial
Message 4 of 6
(615 Views)
24-02-2016 9:56 AM
Ah, thanks.
FYI an MBORC doesn't mean that if you're in that area you're going to have a fault, it's there as a note that if you do experience a problem that needs reporting to Openreach it may take longer than usual to resolve.
Message 5 of 6
(615 Views)
24-02-2016 10:06 PM
It's happening again, started about 18:00 and has been getting worse since then.
I'll raise it at the link supplied, thanks Chris - and thanks for the MBORC information.
Message 6 of 6
(615 Views)
